Durafuse® LT low-temp, high-rel solder paste is bismuth-free, reduces warpage in large BGAs, enhances thermal cycling, drop shock reliability and reduces energy use up to 15%.
Openair Plasma for Semiconductor Manufacturing
Moisture, corrosive gas, oxidation & UV blocking prop-erties. FLUOROSEAL® conformal coating for electrical contacts & ceramic insulator protection.
April 10, 2026 - Updated
December 3, 2025 - Originally Posted
When to Switch to Underfill for BGAs
How do you determine whether repeated thermal shock cycles in the field would require switching to underfill for BGAs? Can underfilled BGAs be removed and replaced?
B.U.
Precision Dispensing Solutions
