Durafuse® LT low-temp, high-rel solder paste is bismuth-free, reduces warpage in large BGAs, enhances thermal cycling, drop shock reliability and reduces energy use up to 15%.
Openair Plasma for Semiconductor Manufacturing
Moisture, corrosive gas, oxidation & UV blocking prop-erties. FLUOROSEAL® conformal coating for electrical contacts & ceramic insulator protection.
April 9, 2013 - Updated
April 9, 2013 - Originally Posted
Eyelets for Plated Hole Repair - Brass or Copper?
We run a repair depot maintaining a very large product line. We often need to repair damaged plated holes on circuit boards and routinely use eyelets. We prefer to use copper eyelets, but they are not always available in the sizes we require, so we substitute brass eyelets.
Our products are class 2 and some class 3. Is it acceptable to use brass eyelets for plated hole repair?
W.M.
Precision Dispensing Solutions
