Durafuse® LT low-temp, high-rel solder paste is bismuth-free, reduces warpage in large BGAs, enhances thermal cycling, drop shock reliability and reduces energy use up to 15%.
Openair Plasma for Semiconductor Manufacturing
Moisture, corrosive gas, oxidation & UV blocking prop-erties. FLUOROSEAL® conformal coating for electrical contacts & ceramic insulator protection.
March 9, 2009 - Updated
March 9, 2009 - Originally Posted
How to bond heavy component to PCB
Can you recommend epoxy to bond a surface mount transformer, 7.5 grams, to a PCB? The board needs to pass 20G vibration and 40G shock tests. What steps do you recommend and in what order should they occur - solder paste, then epoxy, then pick and place, then reflow? Also, how would this process be specified on a drawing, 65% coverage under part, or by volume? Should epoxy pattern under part be dot, striped pattern or solid mass?
C. B.
Precision Dispensing Solutions
