Durafuse® LT low-temp, high-rel solder paste is bismuth-free, reduces warpage in large BGAs, enhances thermal cycling, drop shock reliability and reduces energy use up to 15%.
Openair Plasma for Semiconductor Manufacturing
Moisture, corrosive gas, oxidation & UV blocking prop-erties. FLUOROSEAL® conformal coating for electrical contacts & ceramic insulator protection.
September 18, 2006 - Updated
Wave soldering problems on boards coated with OSP
Over the past several months we have experienced intermittent problems with wave solder voids on PCBs coated with OSP. We suspect variation in the OSP application process, or oxidation of the surface due to insufficient or degraded OSP. Is there a method by which the OSP can be measured or validated to ensure consistent solderability? What is the preferred method for specifying OSP quality?
T.V.
Precision Dispensing Solutions
