Durafuse® LT low-temp, high-rel solder paste is bismuth-free, reduces warpage in large BGAs, enhances thermal cycling, drop shock reliability and reduces energy use up to 15%.
Openair Plasma for Semiconductor Manufacturing
Moisture, corrosive gas, oxidation & UV blocking prop-erties. FLUOROSEAL® conformal coating for electrical contacts & ceramic insulator protection.
October 16, 2006 - Updated
Removing Voids in BGA Process
We have been told that the process described below, to remove voids in a BGA, is not reliable. We would like to know what the consequences are in doing this and what would make the process not reliable.
The process:
We place a small amount of liquid water soluble flux under the BGA. Using a hot air rework station we heat the board and BGA until the solder reaches a liquidus state then lift the BGA about .150" to .250" above the site and hold for 10 to 12 seconds. We then place it back down on the site and finish out the profile. The maximum temperature measured at a solder ball is 210 F.
We X-ray and the voids have been eliminated.
D.V.
Precision Dispensing Solutions
