White Paper Submit Form
Virtual Access Techniques Augments Test Coverage on Limited Access PCB Assemblies
Due to changes in manufacturing requirements, there are
challenges in testing PCBs with limited test access. This paper describes a
powered opens test technique that allows for virtual access on higher-density
PCB assemblies where there is limited test pad access.
Teradyne, Inc.
This page has been viewed 1226 times.
