White Paper Submit Form
White Papers Index
Scavenging
Scavenging, Site Dressing, Residual Solder Removal. What's in a name? "That which we call an onion, by any other name would smell as strong." And, regardless of the name you give it, the objective is the same, namely the clean up of remaining solder after a component or R.F. Shield has been removed from a PCB. This paper will describe the various methods that are available and discuss their pros and cons.
VJ Electronix
This page has been viewed 1198 times.
