White Paper Download Index
Mixed Attachment Technology Studies in RF & Optoelectronic Packages
This paper explores a range of case studies that demonstrate both eutectic and adhesive assembly and the results for closely spaced components. An overview of the technology and accurate placement method is presented for eutectic and adhesive-based attachment for components ranging from 0.18mm x 0.18mm x 0.20mm Si die to 1.7mm x 1.4mm x 0.16mm GaAs die.
Palomar Technologies
