What is the best way of running SPC on a reflow oven?
K. F.
This "Ask the Experts" page has been viewed 305 times.
One of the easiest ways of running SPC on a reflow oven is to use our ECD's OvenRIDER, whereby the product software automatically capture the necessary data and plot the SPC chart.
You just need to run the OvenRIDER through the reflow oven at a same recipe over a desired number of cycles.
EH Lim has been in the PCB Assy industry since 1985, starting at Thomson/Singapore for 5 years before moving to Electrovert Asia Pacifc. Lim was Sales Director for Vitronics Soltec prior to joining ECD in 2007 as Managing Director for Asia Pacific.
The first question to decide upon is whether you want to run SPC on the machine itself (reflow oven) or on the process. The reflow oven will constantly change in order to maintain a stable process.
The oven is trying to compensate for variances in load, ambient temperature, preventive maintenance, wear and tear, flux build up, and much more. It therefore makes more sense to run SPC on the process itself (profile), which is really what determines your production quality.
There are a few accepted methods to run SPC on the process.
Run a profile on a PCB at set intervals such as every shift, every week or other. The profile data may be sent to an Excel spreadsheet or SPC program for charting. Most thermal profilers will have optional SPC programs that will do this for you.
The problem with this approach is that a PCB will deteriorate already after a dozen runs. Changing to a new profile board will introduce unwanted changes to the measurements.
Use a fixture that can last hundreds or thousands of runs. This is usually a good and inexpensive method. Make sure that you use fixtures that accurately represent the profile on the PCB.
The drawback to this method is that running profiles with fixtures is a manual method that limits the number of measurements and prevents real time feedback. It can be labor intensive and interruptive to the production.
There are a few automatic profiling systems on the market that provide automatic SPC charting without any human intervention after the initial programming.
There is an up front investment in these systems of a few thousand US$, but they have a number of benefits:
Real time Cpk data will typically warninstantly of an out of control process while the oven is still producing in-spec products, hence allowing the technician time to adjust the process before defects are produced.
No interruption to the production
Virtually no labor cost associated with collecting and displaying the large quantity of SPC data.
Bjorn Dahle is the President of KIC. He has 20 years experience in the electronic manufacturing industry with various manufacturing equipment companies covering pick & place, screen printers and thermal process management.
What most people mean when they ask, "what is the best way of running SPC…" on most any process is, "what is the most practical way?" This is because SPC math demands a lot from a process.
In fact many SPC tools, like GR&R, cannot be done for a reflow solder thermal process. This is because the GR&R study demands you measure the same "part" more than once.
People assume this means you run the reflow solder profile a second time, which does NOT measure the same part a second time, it produces a second and completely new part, which is not the same as measuring the same part two times. See more discussion on this in my blog.
SPC also demands a lot of data, and even the simplest profiling tools take a little time and discipline to perform. So there is often too little data to allow SPC to really work correctly.
However, corporations willing to take the time to get the needed data from their reflow process will gain much in improved process control, proof that your oven is in control, increased yields, reduced scrap, as well as a marketable differentiator over your competition, in that it shows that you are concerned about your thermal processes.
The most practical way to collect data about your reflow oven, and thus begin to produce meaningful process SPC, is via tools which are designed to measure your oven's capability at a given recipe (oven settings).
These tools have the advantage of remaining stable over many 1000s of uses and thus allow you to see how your oven is performing over time. Unlike the original circuit board, which was used to develop the oven recipe, these tools can confirm that the oven is repeating the same thermal environment long into the future.
They can be use to check if your oven is ready to run at a production recipe at each shift change, every day, after each recipe change, etc, and at the same time capture valuable data which can be used to produce the SPC control and capability charts for the reflow oven.
There are several of these tools to choose from, like the OvenRIDER by ECD. Much more information than can be included here can be found in my blog on this very question of SPC for reflow ovens (Oven Verification) using an OvenRIDER. Please feel free to take a look.
Paul Austen is a 30 year veteran Senior Project Engineer with ECD in Milwaukie, Oregon. Paul has seen and worked with the electronic manufacturing industry from many points of view, including: technician, designer, manufacture, and customer.
Reader Comments
The ideal is obviously to monitor the full time/temperature profile for every solder joint on every board assembled, but with a conventional in line furnace this is not a practical proposition and the techniques mentioned by the panel, although of great practical value, are limited both in how frequently they can measure the process and in the degree of spatial resolution, particularly across the conveyor width.
An alternative approach is one invented by myself in the early '90s and which was patented and then brought to market under license by Quad as "AIR" - Adaptive Intelligent Reflow. This system utlised a line scanning infra-red thermal camera to monitor PCA temperatures as they exited the reflow zone.
This type of camera only requires a narrow slot through which to observe the PCA, so has a negligible effect on the process, and as the PCA moves a 2D map of its peak temperature distribution can be obtained.
Theoretically such a thermal camera could be placed between each zone of the furnace, but this would become expensive as the camera cost is significant (~10kEuros when we did this work) and if the process is giving consistent peak temperatures the extra data is probably of little value for SPC, although it could be used to aid profile set up.
I believe this approach can provide the best and most convenient data for SPC, but when Tyco acquired Quad they stopped in-house production of the Quad designed furnaces and as far as I am aware this technology is currently not available in the market, although at least one other manufacturer has worked on it and may be close to launching something.
