Corporate News Index
July 14, 2010
Nordson ASYMTEK Introduces Flux Jetting System at SEMICON West
 Booth #5947
Selective flux jetting improves package reliability, production throughput, and material utilization
Carlsbad,CA, USA- Nordson ASYMTEK, a leader in dispensing, coating, and jetting technologies, introduces its Spectrum® S-930NSeries selective flux jetting systems at SEMICON West, booth #5947. These inline dispensing systems provide exceptional accuracy and reliability and improve production throughput and material utilization for selectively jetting low-viscosity flux and phase-change high-tack fluxes. The system can also be used for precise coating of other materials such as polyimides.
The Spectrum S-930N, in conjunction with Nordson ASYMTEK's DJ-2200 DispenseJet® valve with coaxial air technology, enables thin flux coatings as low as 5 microns. Selective flux jetting provides edge definition of 0.5 to 1 mm, minimizes flux residue and overspray associated with other spraying techniques, and reduces or eliminates cleaning. The Fluidmove® for Windows® XP (FmXP) software controls the amount of flux jetted to accommodate flip chips of varying bump heights. The system is capable of jetting virtually any pattern at high speeds.
Flux is essential to the overall success of the flip chip process. Flux dispensing is required for flip chip on board, in package, and on flex. In flip chip package assembly, flux is jetted on the substrate pads before die placement to hold the die in place prior to reflow. During the reflow process, flux removes oxides from metal surfaces being soldered which enhances wetting and protects against re-oxidation. If high-tack is required, special phase-change flux materials can be jetted in thin layers. Thin coatings of other materials can also jetted on wafers and substrates prior to applications like laser dicing to reduce contamination caused by ablation fall-out from the dicing process.
"Today's flip chip devices with dense arrays of small solder or copper bumps make jetting preferable to stencil printing and dipping," explained Steve Adamson, Nordson ASYMTEK's semiconductor specialist. "For example, the dipping process performed in component placement equipment is difficult to control for flux coatings below 25 microns. Too much flux can impede underfill flow. Too little flux can result in insufficient soldering."
"Separating the flux and chip placement operations enables higher throughput," continued Adamson, "and jetting dispenses flux into tight places, produces highly accurate dots and lines with tight edge definition, and is a fast process since it doesn't require z-axis motion. One Nordson ASYMTEK customer reported a throughput of 4,000 units per hour using 5x10 pallets with 15 mm2 die."
The Nordson ASYMTEK S-930N flux jetting system is a fully enclosed, vented system that includes safety interlocks and an emergency stop. A dual lane configuration is available for high-volume production (model S-932N). The MH-900 series loaders/unloaders can be added for inline production or in a work-cell configuration with a same-side load/unloader. The S-930N system has a small footprint of just 600 x 1321 mm (23.6 x 52.0 in.) and is scalable in size and configuration to adapt to the needs and requirements of high-volume microelectronics manufacturing.
SEMICON West is being held from July 13-15, 2010 at the Moscone Convention Center, San Francisco, CA.
Nordson ASYMTEK
Roberta Foster-Smith
http://www.nordsonasymtek.com
This page has been viewed 69 times.
More from Nordson ASYMTEK
September 3, 2010 - Corporate News
Nordson ASYMTEK Introduces New Spectrum S-920N-C Stainless Steel Cleanroom Dispenser
Nordson ASYMTEK
July 14, 2010 - Corporate News
Nordson ASYMTEK
May 7, 2010 - Corporate News
Nordson ASYMTEK Wins 2 Awards for Technology Innovation at NEPCON China
Nordson ASYMTEK
April 5, 2010 - Corporate News
Nordson ASYMTEK Features Easy Coat for Windows XP Software for Conformal Coating Applications at APEX
Nordson ASYMTEK
March 19, 2010 - Corporate News
ASYMTEK's Dual Simultaneous Jetting Cuts Dispense Time in Half
Nordson ASYMTEK
March 8, 2010 - Corporate News
Nordson ASYMTEK Receives Intel’s Preferred Quality Supplier Award
Nordson ASYMTEK
October 29, 2009 - Corporate News
Asymtek Features Customer Inspired Conformal Coating Solutions at Productronica
Asymtek
October 20, 2009 - Corporate News
Asymtek Introduces MH-900 Series Material Handling System
Asymtek
August 31, 2009 - Corporate News
Asymtek Names New Manufacturer’s Representative for Mexico
Asymtek
July 1, 2009 - Corporate News
Asymtek Sells Spectrum™ S-910N Dispensing System to DancoTech
Asymtek
June 17, 2009 - Corporate News
Asymtek Promotes Paul Gallo and Tom Schafer
Asymtek
April 29, 2009 - Corporate News
Asymtek Honored with SMT China Vision Award and EM Asia Innovation Award
Asymtek
April 23, 2009 - Corporate News
Asymtek DispenseJet® Systems Enable Consistent and Reliable Dispensing of Liquid Electrolyte Materials for Micro-fuel Cells and Electro-chemical Applications
Asymtek
April 17, 2009 - Corporate News
Asymtek Receives Service Excellence and New Product Innovation Awards
Asymtek
April 1, 2009 - Corporate News
Asymtek Features Customer-Inspired Dispensing Solutions at APEX in Booth 2024
Asymtek
March 18, 2009 - Corporate News
Asymtek Launches New Website in Korean
Asymtek
January 28, 2009 - Corporate News
Fraunhofer Institute Selects Asymtek's Dispensing and Coating Technology
Asymtek
January 21, 2009 - Corporate News
Asymtek's Fiducials-on-the-Fly Locates Fiducials 5 Times Faster
Asymtek
January 20, 2009 - Corporate News
Asymtek Appoints Regional Sales Managers in Korea, Singapore, Malaysia
Asymtek
November 14, 2008 - Corporate News
Asymtek Introduces the New DispenseJet® DJ-100 Jet
Asymtek
September 16, 2008 - Corporate News
Asymtek Expands in Singapore to Meet Increasing Demand
Asymtek
September 2, 2008 - Corporate News
Asymtek Wins 2008 Global Technology Award
Asymtek
July 18, 2008 - Corporate News
Asymtek’s New DispenseJet® DJ-9500is up to Ten Times Faster than Needle Dispensers
Asymtek
June 13, 2008 - Corporate News
Asymtek Celebrates its 25th Anniversary
Asymtek
June 2, 2008 - Corporate News
Asymtek to Demonstrate Latest Dispensing Technologies at Photonics Festival
Asymtek
To find more articles from Nordson ASYMTEK, use the search form below.
