Assembly of Delicate & Fragile Semiconductor Materials
Semiconductor manufacturing can require the use of many different materials including gallium (Ga) base materials. Due to the sensitive nature of some of these materials, unique assembly methods may be required to prevent chipping or fracturing from the assembly process.
Air-Vac Engineering
