Corporate News Index
December 9, 2009
Rogers Introduces Poron Thinstik Soft Seal Foam Material
Woodstock, CT – For use in today’s ever smaller and thinner yet far more functional hand-held devices, the High Performance Foams Division of Rogers Corporation has introduced a new addition to the line of PORON® – PORON ThinStik™ Self-Adhesive Solutions - PORON® ThinStik™ Soft Seal.
PORON ThinStik Self Adhesive Solution is an innovative impact sealing PORON® Urethane gasketing foam with a built-in adhesive layer for enhanced sealing, cushioning and impact resistance.
Highly compressible PORON ThinStik Soft Seal is the ideal product for ultra-thin gap filling, combining the most compressible PORON foam with the most compressible PORON construction. ThinStik Soft Seal is ideal for LCD gasketing and sealing needs in gaps as thin as 0.10 mm.
Combining Rogers PORON foams with a pressure-sensitive adhesive layer enables higher compressibility than traditional laminated adhesive constructions. Manufactured through a unique process that combines the adhesive and foam in one step, PORON ThinStik Self Adhesive Solution material contains fewer incompressible layers compared to traditional constructions, thereby wasting less surface space. The manufacturing process eliminates the extra, incompressible layers of adhesive and PET found in traditional double-side tape. This provides designers the benefit of more foam in a highly compressible package for the same thickness of final gaskets.
Rogers’ acrylic pressure-sensitive adhesive is manufactured to exact specifications to provide a highly reliable bonding surface to a variety of substrates. The adhesive exhibits high quality optical clarity, withstands a wide range of temperatures, and is resistant to chemical exposure.
Compression Force Deflection (CFD) testing comparing PORON ThinStik material and traditional foam with a laminated adhesive demonstrates that ThinStik material is significantly more compressible than the traditional construction. PORON materials in general retain over 90 percent of their original thickness under extreme conditions (material compressed 50 percent for 22 hours at 70º C).
PORON ThinStik is an all-in-one solution, answering designers’ needs for a highly compressible yet compression-set resistant foam for effective sealing and gap filling in ultra-thin devices. Due to its high compression set resistance, PORON ThinStik materials bounce back so gaskets hold their shape and seal for prolonged periods, effectively blocking contaminants and extending product life.
Rogers ThinStik urethane material demonstrates exceptional durability and elasticity under pressure. Due to its high compression set resistance, the material bounces back to enable gaskets to hold their shape and seal for prolonged periods, effectively blocking contaminants like dust and moisture for the life of the product.
Rogers has complete specifications for PORON ThinStik on its website at http://www.rogerscorp.com/. Click on Mobile & Consumer Products under Electronics and see PORON ThinStik under Featured Products.
Rogers Corporation
This page has been viewed 166 times.
More from Rogers Corporation
August 26, 2010 - Corporate News
Rogers to Show Laminate/Prepreg System Solution at Electronics Midwest
Rogers Corporation will be highlighting the benefits of its new 6.15 dielectric-constant RO4360® laminate and RO4460® prepreg system at the ...
Rogers Corporation
July 27, 2010 - Corporate News
Rogers Teams New Ro4460 PREPREG with RO4360 Laminate
Rogers Corporation has developed the perfect match for their popular RO4360™ laminate: RO4460™ prepreg. Both materials feature dielectric ...
Rogers Corporation
May 5, 2010 - Corporate News
Rogers To Show Thermal & Circuit Solutions At IEEE Int'l Microwave Symposium
Rogers Corporation
May 4, 2010 - Corporate News
Rogers 4360 High Frequency Thermoset Material Wins Award
Rogers Corporation
April 27, 2010 - Corporate News
Rogers To Spotlight Practical PCB Solutions At Del Mar Electronics & Design Show
Rogers Corporation
March 31, 2010 - Corporate News
Rogers Corporation to Display Proven PCB Solutions at IPC APEX EXPO
Rogers Corporation will display some of its high-performance materials for electronic printed circuit boards at the upcoming IPC APEX EXPO™ in ...
Rogers Corporation
March 25, 2010 - Corporate News
Rogers Corp Earns Distinguished Designcon 2010 Paper Award
Rogers Corporation
December 9, 2009 - Corporate News
Rogers Corporation
October 14, 2009 - Corporate News
Rogers Corp. To Showcase Innovative Advanced Materials at Productronica
Rogers Corporation
September 15, 2009 - Corporate News
Rogers Corp Announces Introduction of RO4360 6.15 DK Laminates
Rogers Corporation
August 27, 2009 - Corporate News
Rogers Corp.To Display High Frequency Laminates at IPC Midwest & PCB West Shows
Rogers Corporation
July 24, 2009 - Corporate News
Rogers Corp. New RO4730 Laminates For Light, Low-Loss Antenna Designs
Rogers Corp.
May 13, 2009 - Corporate News
Rogers To Highlight Breakthrough UL Rating, Advanced Thermal Solutions at PCIM
Rogers Corporation
May 12, 2009 - Corporate News
Rogers Introduces Low-Z Axis Material For Airborne Antenna Applications
Rogers Corporation
May 11, 2009 - Corporate News
Rogers to Introduce New Product & Showcase HF Laminates at IEEE MTT-S
Rogers Corporation
May 8, 2009 - Corporate News
Rogers High Performance Foams Division To Highlight 2 Key Products At SAMPE
Rogers Corporation
May 5, 2009 - Corporate News
Rogers Corp Showcases High Frequency Laminates at Del Mar Electronics Show
Rogers Corporation
April 23, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates at PCB East
Rogers Corporation
April 9, 2009 - Corporate News
Rogers New RT/DUROID Laminates Wins New Product Award
Rogers Corporation
April 8, 2009 - Corporate News
Rogers Introduces RO4000 LoPro Laminates
Rogers Corporation
April 7, 2009 - Corporate News
Rogers To Feature Printed Electronics, Illuminated Advertising Solutions at Printed Electronics
Rogers Corporation
March 30, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates At CTIA 2009
Rogers Corporation
March 17, 2009 - Corporate News
Rogers Corporation Showcases High Frequency Laminates At IPC APEX EXPO
Rogers Corporation
February 26, 2009 - Corporate News
Rogers To Feature Advanced Circuit Materials At iMAPS Conference & Exhibition
Rogers Corporation
February 25, 2009 - Corporate News
Rogers Corp. to Showcase High Frequency Laminates at Satellite 2009 EXPO
Rogers Corporation
To find more articles from Rogers Corporation, use the search form below.
