Corporate News Index
November 5, 2009
Strategic relationship with SiliconAid extends ASSET's ScanWorks platform into chip test and verification
Chip debugger will be integrated into ScanWorks®; ASSET to resell IEEE P1687 insertion and verification tools
Richardson, TX – ASSET® InterTech (http://www.asset-intertech.com/), the leading supplier of open tools for embedded instrumentation, and SiliconAid Solutions (http://www.siliconaid.com/), Austin, TX., have formed a strategic relationship whereby ASSET will integrate its first integrated circuit (IC) test tool into the ScanWorks® platform for embedded instrumentation and resell SiliconAid’s insertion and verification tools that support the emerging IEEE P1687 Internal JTAG (IJTAG) standard. SiliconAid is a supplier of world class chip verification and debug tools that support the IEEE 1149.1 Boundary-Scan Standard, which is commonly referred to as JTAG after the Joint Test Action Group which initiated development of the standard.
“This is just the first step toward our vision of a continuous test flow beginning at the chip level and extending to circuit boards and systems,” said Glenn Woppman, president and CEO of ASSET. “Beyond this chip debugger that we’ll be integrating into the ScanWorks platform, we can see a time when extensive chip tests can be re-used in board and system test, saving manufacturers considerably on test development and shortening time-to-market. We’re also excited about promoting SiliconAid’s IEEE P1687 IJTAG tools. We want to encourage the adoption of this emerging standard because we believe it will be critical to the effective utilization of embedded instrumentation in future test and measurement applications.”
SiliconAid’s JTD™ chip debugger, which will be integrated into ScanWorks immediately, is a robust real-time test and debug tool that can monitor structures inside chips and give visibility through an intuitive graphical interface to the engineer who is debugging the device. Although ASSET will initially resell SiliconAid’s IEEE P1687 IJTAG synthesis (JTS™) and verification (JTV™) tools, future plans could call for these tools to be integrated into ScanWorks as well. JTS™ and JTV™ allow chip designers to automatically insert IJTAG capabilities into chips and subsequently verify the implementation. IEEE P1687 provides a standard interface to instrumentation embedded in chips.
“We are excited about teaming up with ASSET to resell our tools and to help lead the industry’s adoption of the IJTAG IEEE P1687 standard,” said Jim Johnson, president of SiliconAid. “This standard is not just important for our two companies. It will be critical to the industry as embedded instrumentation proliferates in next-generation devices. Standards like P1687 enable a higher level of integration and automation, beginning with chip design and test, and then transitioning seamlessly into board test. Adding IEEE P1687 IJTAG tools into our suite is a natural next step for us to leverage our existing products and offer more value to our customers.”
As part of the new relationship, the two companies agreed to do joint marketing. The first such activity will be the 2009 International Test Conference (ITC), Nov. 2-6 in the Austin Convention Center, Austin, TX. Both companies will have booths at this year’s ITC and ASSET’s booth (No. 117) will feature a demonstration of SiliconAid’s JTD TMdebugger. In addition, ASSET will feature the JTD™ debugger at Productronica in Munich, Germany, Nov. 10-13 (Hall A1, Stand 470).
ScanWorks® – The Embedded Instrumentation Platform
ASSET, through its ScanWorks platform, is applying the experience it has gained from two decades as a leading supplier of IEEE 1149.1 boundary-scan (JTAG) test tools to the development of open embedded instrumentation tools. The boundary-scan infrastructure that is embedded into chips and circuit boards is one of several technologies which can form the basis for an embedded instrumentation toolset. In recent years, ASSET has significantly enhanced ScanWorks beyond boundary-scan test with the addition of other embedded instrumentation technologies, including processor-controlled test (PCT) and tools for Intel® IBIST (Interconnect Built-In Self Test).
SiliconAid’s SAJE SM Tool Suite
The SiliconAid JTAG Environment (SAJE SM) is comprised of tools (JTV TM, JTS TM, JTD TM) that focus on chip level JTAG needs for 1149.1, 1149.6, and now IEEE P1687. SAJE SM can be integrated into any major chip design process to handle JTAG requirements. The SAJE SM suite performs semantic checking, simulation-based verification, automatic test program generation (ATPG) and interactive debugging. Now the SAJE SM suite offers these functions in support of the IEEE P1687 standard. SAJESM can leverage design simulation information into automatic test equipment (ATE) and board test with test patterns and an interactive debugger (JTD TM).
About ASSET InterTech
ASSET InterTech is the leading supplier of open tools for embedded instrumentation for design validation, test and debug. The ScanWorks platform provides automation, access and analysis tools in one environment. Users can quickly and easily validate and test semiconductors, circuit boards or entire systems during every phase of a product's life, including design, manufacturing/repair and field maintenance. ASSET InterTech is located at 2201 North Central Expressway, Suite 105, Richardson, TX 75080.
About SiliconAid Solutions, Inc. (http://www.siliconaid.com/)
SiliconAid Solutions, Inc. was founded in 2001 and is headquartered in Austin, Texas. SiliconAid has a JTAG software development group and a world class design-for-test (DFT) consulting group supporting all electronic design automation (EDA) DFT tools. SiliconAid has developed a full suite of tools for JTAG creation, verification and debug. SiliconAid Solutions, Inc. is a privately held Texas corporation located at 9901 Brodie Lane, Suite 160217, Austin TX 78748.
ASSET® InterTech
Alan Sguigna
This page has been viewed 246 times.
More from ASSET® InterTech
July 16, 2010 - Corporate News
ASSET®,IPextreme collaborate to enable ScanWorks® as an IEEE test solution
ASSET® InterTech, Inc. will integrate test adapter intellectual property (IP) from IPextreme into its ScanWorks® platform for embedded ...
ASSET® InterTech, Inc.,
May 20, 2010 - Corporate News
ASSET is first to support new Intel® Xeon® processors
ASSET® InterTech
March 12, 2010 - Corporate News
ScanWorks validation and testing tools for Intel®’s future
ASSET® InterTech
February 25, 2010 - Corporate News
ScanWorks platform for embedded instruments named finalist for EDN's Innovation Award
ASSET® InterTech
January 7, 2010 - Corporate News
ASSET notches two more Best in Test finalist awards
ASSET® InterTech
November 6, 2009 - Corporate News
ASSET’s ScanWorks supports PLX Technology’s PCI Express switch family’s visionPAK diagnostic toolset
ASSET® InterTech
November 5, 2009 - Corporate News
ASSET® InterTech
September 25, 2009 - Corporate News
ASSET's new interposer opens test access to Intel® Xeon® processors 5500 series and Core™ i7 processors
With ASSET® InterTech's new LGA1366 interposer, design, test and field repair engineers are able to access the debug port on the Intel® Xeon® ...
ASSET® InterTech
August 25, 2009 - Corporate News
Cray selects ASSET’s ScanWorks platform for embedded diagnostics in next-generation supercomputers
ASSET® InterTech’s ScanWorks®
August 10, 2009 - Corporate News
ASSET’s Dispatcher for ScanWorks® applies tests simultaneously to an unlimited number of circuit boards
Dispatcher slashes the cost of test by reducing the need for multiple testers and enabling multitasking test operators. The new Dispatcher for ...
Asset
May 7, 2009 - Corporate News
ASSET ScanWorks platform is first to support for Intel Xeon processor 5500
ASSET InterTech
February 9, 2009 - Corporate News
ASSET InterTech’s Woppman named one of four finalists for Innovator of the Year
ASSET InterTech
January 29, 2009 - Corporate News
ASSET Remote Instrumentation Controller named Best In Test Finalist
ASSET® InterTech
January 23, 2009 - Corporate News
ASSET’s ScanWorks for Embedded Boundary Scan offers in-system JTAG test and diagnostics
ASSET® InterTech
October 29, 2008 - Corporate News
ASSET joins Synopsys in-Sync Program
ASSET
September 29, 2008 - Corporate News
ASSET's Internet-based controller family enables world wide test
The new Remote Instrumentation Controller family from ASSET® InterTech is the industry's first to apply JTAG/boundary scan tests directly over ...
ASSET InterTech
September 16, 2008 - Corporate News
ASSET brings JTAG test tools perspective to IEEE 1149.7
ASSET InterTech
September 12, 2008 - Corporate News
Flexible licensing gives global access to ASSET’s MicroMaster JTAG functional test system
ASSET® InterTech
September 2, 2008 - Corporate News
ASSET becomes founding member of iNEMI
ASSET® InterTech recently became a founding member of the International Electronics Manufacturing Initiative's (iNEMI) boundary scan adoption ...
ASSET InterTech
ASSET’s ScanWorks(R) Supports On-Chip Evaluation
ASSE InterTech
August 18, 2008 - Corporate News
Maxim seeks ASSET ScanWorks'
ASSET(R) InterTech has announced that its ScanWorks(R) platform supports unique margining and forensics capabilities through several of Maxim ...
ASSET® InterTech
June 17, 2008 - Corporate News
ASSET is first to support Intel’s new Nehalem micro-architecture
ASSET
June 13, 2008 - Corporate News
ASSET works with Cadence to drive embedded instrumentation for deep analysis of complex ICs
ASSET InterTech, Inc.
May 22, 2008 - Corporate News
ASSET® Joins Mentor OpenDoor Program to ensure JTAG interoperability
ASSET InterTech
May 5, 2008 - Corporate News
ASSET commits to developing open embedded instrument tools
ASSET® InterTech Inc.
To find more articles from ASSET® InterTech, use the search form below.
