Kyzen to Highlight AQUANOX® A4241 at Wisconsin Expo &Tech Forum
NASHVILLE — Kyzen, a world leading provider of environmentally responsible precision cleaning products for electronics and high-technology manufacturing operations, announces that it will feature AQUANOX® A4241 PCB and Stencil Cleaner at the upcoming Wisconsin/Great Lakes Expo & Tech Forum, scheduled to take place Tuesday, November 10, 2009 at the Wyndham Airport Hotel in Milwaukee, WI.
AQUANOX® A4241 is an award winning aqueous cleaning solution designed with a revolutionary inhibition technology to be effective on the toughest soils while protecting even the most sensitive parts from etch or darkening. Kyzen introduces a product that can be used in spray batch, spray in-line and stencil cleaning processes. A4241 will provide brilliant solder joints with no sump side additives and consistent cleaning results with minimal bath monitoring.
A non-flammable, non-corrosive liquid, AQUANOX® A4241 has proven compatible with all materials commonly used in electronics assembly manufacturing and cleaning processes. AQUANOX® A4241 is a non-hazardous, biodegradable aqueous solution that contains no CFCs or HAPs.
The Kyzen Applications Laboratory has evaluated AQUANOX® A4241 for effective removal of nearly 300 soldering materials from the world’s leading suppliers including: Senju, Alpha, Kester, Indium, AIM, Koki, Nihon Superior, Balver Zinn GmbH & Co. KG, Amtech, Cobar, EFD, Florida Cirtech, Heraeus, Interflux, Loctite, Promosol, Qualitek and Shenmao.
AQUANOX A4241 is available in one, five, and 55 gallon containers.
Kyzen® and AQUANOX® are registered trademarks in the United States of Kyzen Corporation.
August 6, 2010 - Corporate News Let Kyzen Save You 50% on Stencil Cleaning Solutions Kyzen will showcase its award-winning stencil cleaning solutions LONOX® L5608 and LONOX® L5611 in booth 2F10 at the upcoming NEPCON South ...
Kyzen
