Corporate News Index
September 23, 2009
Kyzen to Highlight METALNOX® M6960 and METALNOX® M6330 at CMTS
NASHVILLE — Kyzen, a world leading provider of environmentally responsible precision cleaning products for electronics and high-technology manufacturing operations, announces that it will feature METALNOX® M6960 and METALNOX® M6330 in booth 33007 at the upcoming Canadian Manufacturing Technology Show, scheduled to take place October 19-22, 2009 at the Direct Energy Centre in Toronto, ON, Canada.
METALNOX® M6960 is an industrial vapor cleaning solvent designed for use in standard vapor degreasing equipment as a drop-in replacement for chlorinated solvents. M6960 is used as received for the removal of typical industrial soils including stamping, drawing, forming and hydraulic oils, buffing compounds, greases, and shop dirt from ferrous and non-ferrous substrates.
METALNOX® M6960 has superior performance characteristics over other brominated-based cleaning solvents due to its unique stabilizer package that allows for longer bath life.
METALNOX® M6960 concentration should be monitored and maintained on a routine and regular basis depending on tank use. Best results are obtained with an Acid Acceptance Test Kit available from Kyzen.
Kyzen® Booster 6 is available for sump adjustment as required for prolonged bath life.
METALNOX® M6330 is a high alkaline aqueous solution designed to clean and brighten a wide variety of metal parts. M6330 will provide long-term corrosion protection on ferrous and copper based alloys, including brass and bronze. M6330 is intended to be diluted for use in spray or immersion systems.
METALNOX® M6330 is particularly effective in removing heavy greases and oils found in typical CNC machining operations. M6330 will not discolor sensitive metals such as brass and other copper based alloys. Aluminum alloys should be tested to determine compatibility.
A non-flammable, corrosive, low VOC aqueous solution, METALNOX® M6330 has proven compatible with most materials of construction used in industrial parts cleaning systems and processes. METALNOX® M6330 contains no CFCs or HAPs.
METALNOX® M6960 is available in 50 and 550 lb containers. METALNOX® M6330 is available in one, five, and 55 gallon containers.
Kyzen® and METALNOX® are registered trademarks in the United States of Kyzen Corporation.
Kyzen
Tom Forsythe
http://www.kyzen.com
This page has been viewed 270 times.
More from Kyzen
September 1, 2010 - Corporate News
For the Cleanest Boards in the Midwest, Come See Kyzen's AQUANOX® A4703 at IPC Electronics Midwest
Kyzen Corporation
August 31, 2010 - Corporate News
See Kyzen’s Award-Winning AQUANOX® A4703 Cleaning Chemistry at the SMTA Capital Expo & Tech Forum
Kyzen
August 24, 2010 - Corporate News
Mike Bixenman Discusses Medical Cleaning Process Considerations at MEPTEC
Kyzen announces that Dr. Mike Bixenman will present a paper titled "System Integration Medical Cleaning Process Considerations" at ...
Kyzen
August 18, 2010 - Corporate News
Kyzen to Offer Products for Every Metal Cleaning Process at IMTS
Kyzen will display its complete METALNOX® product line, offering products for every metal cleaning process, in booth E-5730 at the upcoming ...
Kyzen
August 16, 2010 - Corporate News
Get Expert Cleaning Advice from Kyzen's Dr. Mike Bixenman at the SMTA Tampa
Kyzen announces that Dr. Mike Bixenman will speak on Eco-Centric Electronic Assembly Cleaning Agents at the upcoming SMTA Tampa Bay ...
Kyzen
August 6, 2010 - Corporate News
Let Kyzen Save You 50% on Stencil Cleaning Solutions
Kyzen will showcase its award-winning stencil cleaning solutions LONOX® L5608 and LONOX® L5611 in booth 2F10 at the upcoming NEPCON South ...
Kyzen
August 5, 2010 - Corporate News
See Eco-Friendly Advanced Electronics Cleaning Solutions by Kyzen at NEPCON South China
Kyzen Corporation
July 26, 2010 - Corporate News
Kyzen to Showcase AQUANOX® A4703 at SMTA Wisconsin/Great Lakes Expo
Kyzen
July 1, 2010 - Corporate News
Kyzen to Highlight AQUANOX® A4703 at SMTA Ohio Valley Expo & Tech Forum
Kyzen
June 30, 2010 - Corporate News
Kyzen Holds Successful Cleaning Seminarat NEPCON West China 2010
Kyzen announces that it held a successful cleaning seminar to discuss electronics cleaning. The seminar was held on Wednesday, June 23, 2010 ...
Kyzen Corporation
June 23, 2010 - Corporate News
Kyzen's Debbie Carboni Selected to Present at SMTA West PA Chapter Meeting
Kyzen announces that Debbie Carboni, Mid-Atlantic Territory Manager, will present a paper titled "Cause, Effects and Solutions for White Residue ...
Kyzen
June 7, 2010 - Corporate News
Kyzen to Showcase Advanced Cleaning Chemistries at NEPCON West China
Kyzen
June 1, 2010 - Corporate News
Kyzen to Highlight AQUANOX® A4703 at SMTA Upper Midwest Expo
Kyzen
May 17, 2010 - Corporate News
Kyzen and Head-Tech Engineering Hold Successful Cleaning Seminar in Israel
Kyzen announces that it held a successful seminar titled "Advanced Cleaning Materials and Processes” in conjunction with Head-Tech Engineering ...
Kyzen Corporation
May 13, 2010 - Corporate News
Kyzen's Serge Tuerlings to Hold Commercial Presentation at Brasage Soldering 2010
Kyzen
May 12, 2010 - Corporate News
Kyzen and E-Tronics to Hold Technology Day in Hungary
Kyzen
May 11, 2010 - Corporate News
Kyzen to Highlight METALNOX® M6330 and METALNOX® M6319 at EASTEC
Kyzen
May 7, 2010 - Corporate News
Kyzen's Mike Bixenman to Present Research at Conf. on Soldering, Reliability
Kyzen Corporation
May 6, 2010 - Corporate News
Kyzen to Highlight AQUANOX® A4241, CYBERSOLV®141-R at Brasage Soldering
Kyzen Corporation
May 5, 2010 - Corporate News
Kyzen Receives Member Sponsor of the Year Award from SMTA China
Kyzen announces that it was named Member Sponsor of the Year at the SMTA China East 2010 Award Presentation Ceremony. The award was presented ...
Kyzen Corporation
May 4, 2010 - Corporate News
Kyzen to Highlight AQUANOX® A4703 at SMTA Upper Toronto Expo, Tech Forum
Kyzen Corporation
April 29, 2010 - Corporate News
Kyzen's Rich Brooks Holds Successful Presentation at SMTA Silicon Valley Chapter Meeting
Kyzen announces that Rich Brooks held a successful presentation at the SMTA Silicon Valley Chapter meeting, which took place on Thursday, April ...
Kyzen Corporation
April 28, 2010 - Corporate News
Kyzen's AQUANOX® A4703 Wins a 2010 Innovation Award
Kyzen Corporation
April 27, 2010 - Corporate News
Kyzen's Chuck Sexton to Present at the 2010 Process Cleaning Expo
Kyzen announces that Chuck Sexton, Industrial Products Sales Manager, will present a case study titled "Conversion to Aqueous Cleaning from ...
Kyzen
April 22, 2010 - Corporate News
Kyzen’s Charlie Pitarys to Present at the 2010 Process Cleaning Expo
Kyzen announces that Charlie Pitarys, Sales Technical Manager, will hold a presentation titled “Cleaner Selection Simplified” at the upcoming Process ...
Kyzen Corporation
To find more articles from Kyzen, use the search form below.
