Corporate News Index
August 27, 2009
Rogers Corp.To Display High Frequency Laminates at IPC Midwest & PCB West Shows
Chandler, AZ - Rogers Corporation (NYSE:ROG), a leading supplier of high-frequency laminates for circuit boards in amplifiers, microwave radios, base-station antennas, and routers and switches, showcases a number of its high-performance and low-cost laminate materials for commercial and military applications at the upcoming PCB West 2009 this September 15-16 in Santa Clara, CA (Booth #36) and at the IPC Midwest 2009 Show this September 23-24 in Schaumburg, IL (Booth #502).
At both shows, Rogers will provide examples of its many innovative printed-circuit laminate materials, including its low-cost RO4730™ LoPro™ antenna-grade material. Benefits of this laminate include a dielectric constant of 3.0, compatibility with conventional FR-4 and high-temperature lead-free solder processing, and a lightweight composition (30% lighter than glass-filled PTFE laminates). Visitors to either show can also learn about Rogers RO3730™ ceramic-filled laminates. These high-performance laminates are engineered for antenna designers as a cost-effective PTFE-based laminate alternative. The RO3730 materials are reinforced by woven glass for excellent electric performance and outstanding structural stability, with low Z-axis coefficient of thermal expansion (CTE) for repeatable plated-through-hole (PTH) fabrication. The RO3730 laminates feature low passive intermodulation (PIM) performance and a dielectric constant of 3.0, making them ideal for use in 3G and 4G cellular base stations.
For applications where high performance is a prime consideration, visitors to both shows can also examine Rogers RT/duroid® 5880LZ laminate materials, with the industry’s lowest available dielectric constant of 1.96 ± 0.04 at 10 GHz. Fabricated with a unique filler material, these light-weight PTFE composites feature low dissipation factor (typically 0.0019 at 10 GHz) and low Z-axis CTE for superior PTH reliability. They exhibit consistent panel-to-panel dielectric constant and are easily cut, sheared, and machined in support of low-cost manufacturing processes.
Finally, Rogers will feature its RO4000® and Theta™ materials. The RO4000 laminates offer uniform dielectric constant across each sheet, with low dissipation losses, low CTE, and excellent dimensional stability. Halogen-free Theta materials offer the low insertion loss and outstanding thermal characteristics needed for superior mechanical and electrical performance in multilayer circuits. With a dielectric constant of 4.01 at 10 GHz and a low dissipation factor, (0.0118 at 10 GHz) the environmentally friendly Theta circuit materials are available in a wide range of laminate and prepreg thickness options.
Rogers Corporation
http://www.rogerscorp.com/
This page has been viewed 199 times.
More from Rogers Corporation
August 26, 2010 - Corporate News
Rogers to Show Laminate/Prepreg System Solution at Electronics Midwest
Rogers Corporation will be highlighting the benefits of its new 6.15 dielectric-constant RO4360® laminate and RO4460® prepreg system at the ...
Rogers Corporation
July 27, 2010 - Corporate News
Rogers Teams New Ro4460 PREPREG with RO4360 Laminate
Rogers Corporation has developed the perfect match for their popular RO4360™ laminate: RO4460™ prepreg. Both materials feature dielectric ...
Rogers Corporation
May 5, 2010 - Corporate News
Rogers To Show Thermal & Circuit Solutions At IEEE Int'l Microwave Symposium
Rogers Corporation
May 4, 2010 - Corporate News
Rogers 4360 High Frequency Thermoset Material Wins Award
Rogers Corporation
April 27, 2010 - Corporate News
Rogers To Spotlight Practical PCB Solutions At Del Mar Electronics & Design Show
Rogers Corporation
March 31, 2010 - Corporate News
Rogers Corporation to Display Proven PCB Solutions at IPC APEX EXPO
Rogers Corporation will display some of its high-performance materials for electronic printed circuit boards at the upcoming IPC APEX EXPO™ in ...
Rogers Corporation
March 25, 2010 - Corporate News
Rogers Corp Earns Distinguished Designcon 2010 Paper Award
Rogers Corporation
December 9, 2009 - Corporate News
Rogers Introduces Poron Thinstik Soft Seal Foam Material
Rogers Corporation
October 14, 2009 - Corporate News
Rogers Corp. To Showcase Innovative Advanced Materials at Productronica
Rogers Corporation
September 15, 2009 - Corporate News
Rogers Corp Announces Introduction of RO4360 6.15 DK Laminates
Rogers Corporation
August 27, 2009 - Corporate News
Rogers Corporation
July 24, 2009 - Corporate News
Rogers Corp. New RO4730 Laminates For Light, Low-Loss Antenna Designs
Rogers Corp.
May 13, 2009 - Corporate News
Rogers To Highlight Breakthrough UL Rating, Advanced Thermal Solutions at PCIM
Rogers Corporation
May 12, 2009 - Corporate News
Rogers Introduces Low-Z Axis Material For Airborne Antenna Applications
Rogers Corporation
May 11, 2009 - Corporate News
Rogers to Introduce New Product & Showcase HF Laminates at IEEE MTT-S
Rogers Corporation
May 8, 2009 - Corporate News
Rogers High Performance Foams Division To Highlight 2 Key Products At SAMPE
Rogers Corporation
May 5, 2009 - Corporate News
Rogers Corp Showcases High Frequency Laminates at Del Mar Electronics Show
Rogers Corporation
April 23, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates at PCB East
Rogers Corporation
April 9, 2009 - Corporate News
Rogers New RT/DUROID Laminates Wins New Product Award
Rogers Corporation
April 8, 2009 - Corporate News
Rogers Introduces RO4000 LoPro Laminates
Rogers Corporation
April 7, 2009 - Corporate News
Rogers To Feature Printed Electronics, Illuminated Advertising Solutions at Printed Electronics
Rogers Corporation
March 30, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates At CTIA 2009
Rogers Corporation
March 17, 2009 - Corporate News
Rogers Corporation Showcases High Frequency Laminates At IPC APEX EXPO
Rogers Corporation
February 26, 2009 - Corporate News
Rogers To Feature Advanced Circuit Materials At iMAPS Conference & Exhibition
Rogers Corporation
February 25, 2009 - Corporate News
Rogers Corp. to Showcase High Frequency Laminates at Satellite 2009 EXPO
Rogers Corporation
To find more articles from Rogers Corporation, use the search form below.
