Hermetic Sealing Using Low Impedance Projection Welding
This new projection welder provides higher yields and uses less energy than older equipment. This seal method offers a unique combination of strength, robustness, hermeticity, minimal temperature rise, and low cost.
Hermetric, Inc.
