Corporate News Index
May 11, 2009
Rogers to Introduce New Product & Showcase HF Laminates at IEEE MTT-S
Chandler, AZ - Rogers Corporation (NYSE:ROG), a leading supplier of high frequency laminates, will announce the launch of another new member to its family of advanced circuit materials at the 2009 International Microwave Symposium (IEEE MTT-S) to be held at the Boston Convention & Exhibition Center June 9th-11th (Booth # 1018.)
The Advanced Circuit Materials Division will also be showcasing recently introduced materials especially targeted to meet next generation material requirements for the microwave industry:
RO4000® LOPRO™ Laminates
RO4000 LoPro laminates implement a special interface technology to enable the use of a very low profile reverse-treat copper foil while maintaining copper peel strength equal to or better than standard RO4000 materials. RO4000 LoPro laminates combine the best-in-class electrical and thermo-mechanical reliability of RO4000 laminates with improved insertion loss and outstanding passive intermodulation (PIM) characteristics.
RT/duroid® 5880LZ Laminates
The award winning RT/duroid 5880LZ material is a PTFE composite designed for exacting stripline and microstrip circuit applications. This groundbreaking filler system results in a low density (1.37 gm/cm3), lightweight material, making it an ideal choice for high performance weight sensitive applications such as airborne antennas. RT/duroid 5880LZ laminate has a dielectric constant (Dk) of 1.96 @ 10 GHz, providing the lowest Dk of a copper clad microwave material available today. In addition, the dielectric constant is uniform from panel-to-panel and constant over a wide frequency range, with a low z-axis TCDk of +22 ppm/°C. Its low dissipation factor extends the usefulness of RT/duroid 5880LZ to Ku-band and above.
In addition, the following well known commercial grade materials for high performance applications will be on display:
RO3000® Laminates: Features low dielectric loss for high frequency applications; uniform mechanical properties, ideal for multilayer boards; as well as stable Dk versus frequency and temperature.
R/flex® 8080 Photoimageable Covercoat Materials: Designed to provide uniform coverage in mass production applications, Rogers R/flex 8080 enables printed circuit board manufacturers to achieve ultra-fine, high precision etch patterns that have traditionally been unattainable through conventional screen printing. The photoimageable covercoat materials provide outstanding imaging resolution, flexibility and creaseability, required for developing today's high-density flexible printed circuits.
Rogers Corporation
http://www.rogerscorp.com
This page has been viewed 195 times.
More from Rogers Corporation
August 26, 2010 - Corporate News
Rogers to Show Laminate/Prepreg System Solution at Electronics Midwest
Rogers Corporation will be highlighting the benefits of its new 6.15 dielectric-constant RO4360® laminate and RO4460® prepreg system at the ...
Rogers Corporation
July 27, 2010 - Corporate News
Rogers Teams New Ro4460 PREPREG with RO4360 Laminate
Rogers Corporation has developed the perfect match for their popular RO4360™ laminate: RO4460™ prepreg. Both materials feature dielectric ...
Rogers Corporation
May 5, 2010 - Corporate News
Rogers To Show Thermal & Circuit Solutions At IEEE Int'l Microwave Symposium
Rogers Corporation
May 4, 2010 - Corporate News
Rogers 4360 High Frequency Thermoset Material Wins Award
Rogers Corporation
April 27, 2010 - Corporate News
Rogers To Spotlight Practical PCB Solutions At Del Mar Electronics & Design Show
Rogers Corporation
March 31, 2010 - Corporate News
Rogers Corporation to Display Proven PCB Solutions at IPC APEX EXPO
Rogers Corporation will display some of its high-performance materials for electronic printed circuit boards at the upcoming IPC APEX EXPO™ in ...
Rogers Corporation
March 25, 2010 - Corporate News
Rogers Corp Earns Distinguished Designcon 2010 Paper Award
Rogers Corporation
December 9, 2009 - Corporate News
Rogers Introduces Poron Thinstik Soft Seal Foam Material
Rogers Corporation
October 14, 2009 - Corporate News
Rogers Corp. To Showcase Innovative Advanced Materials at Productronica
Rogers Corporation
September 15, 2009 - Corporate News
Rogers Corp Announces Introduction of RO4360 6.15 DK Laminates
Rogers Corporation
August 27, 2009 - Corporate News
Rogers Corp.To Display High Frequency Laminates at IPC Midwest & PCB West Shows
Rogers Corporation
July 24, 2009 - Corporate News
Rogers Corp. New RO4730 Laminates For Light, Low-Loss Antenna Designs
Rogers Corp.
May 13, 2009 - Corporate News
Rogers To Highlight Breakthrough UL Rating, Advanced Thermal Solutions at PCIM
Rogers Corporation
May 12, 2009 - Corporate News
Rogers Introduces Low-Z Axis Material For Airborne Antenna Applications
Rogers Corporation
May 11, 2009 - Corporate News
Rogers Corporation
May 8, 2009 - Corporate News
Rogers High Performance Foams Division To Highlight 2 Key Products At SAMPE
Rogers Corporation
May 5, 2009 - Corporate News
Rogers Corp Showcases High Frequency Laminates at Del Mar Electronics Show
Rogers Corporation
April 23, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates at PCB East
Rogers Corporation
April 9, 2009 - Corporate News
Rogers New RT/DUROID Laminates Wins New Product Award
Rogers Corporation
April 8, 2009 - Corporate News
Rogers Introduces RO4000 LoPro Laminates
Rogers Corporation
April 7, 2009 - Corporate News
Rogers To Feature Printed Electronics, Illuminated Advertising Solutions at Printed Electronics
Rogers Corporation
March 30, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates At CTIA 2009
Rogers Corporation
March 17, 2009 - Corporate News
Rogers Corporation Showcases High Frequency Laminates At IPC APEX EXPO
Rogers Corporation
February 26, 2009 - Corporate News
Rogers To Feature Advanced Circuit Materials At iMAPS Conference & Exhibition
Rogers Corporation
February 25, 2009 - Corporate News
Rogers Corp. to Showcase High Frequency Laminates at Satellite 2009 EXPO
Rogers Corporation
To find more articles from Rogers Corporation, use the search form below.
