Corporate News Index
May 5, 2009
Rogers Corp Showcases High Frequency Laminates at Del Mar Electronics Show
Rogers to Promote Important New Products
Chandler, AZ - Rogers Corporation (NYSE:ROG), a leading supplier of high frequency laminates will be promoting important new members to its family of advanced circuit materials at the Del Mar Electronics Show 2009 held at the Del Mar Fairgrounds in San Diego, California May 6th and 7th (Booth #622.)
Highlights include:
RO4000® LoPro™ Laminates
RO4000 LoPro laminates implement a special interface technology to enable the use of a very low profile reverse-treat copper foil while maintaining copper peel strength equal to or better than standard RO4000 materials. RO4000 LoPro laminates combine the best-in-class electrical and thermo-mechanical reliability of RO4000 laminates with improved insertion loss and outstanding passive intermodulation (PIM) characteristics.
RT/duroid® 5880LZ Laminates
The award winning RT/duroid 5880LZ material is a PTFE composite designed for exacting stripline and microstrip circuit applications. Our ground-breaking filler system results in a low density (1.37 gm/cm3), lightweight material making it an ideal choice for high performance weight sensitive applications such as airborne antennas. RT/duroid 5880LZ laminate has a dielectric constant (Dk) of 1.96 @ 10 GHz, providing the lowest Dk of a copper clad microwave material available today. With an exceptional TCDK (thermal coefficient of dielectric constant) of 22 PPM/°C, 5880LZ enables consistent circuit performance and stable dielectric constant versus temperature. In addition, the dielectric constant is uniform from panel-to-panel and constant over a wide frequency range. Its low dissipation factor extends the usefulness of RT/duroid 5880LZ to Ku-band and above.
In addition, the following well known commercial grade materials for high performance applications will be on display:
RO3000® laminates: Features low dielectric loss for high frequency applications; uniform mechanical properties, ideal for multi-layer board; as well as stable Dk versus frequency and temperature.
R/flex® 8080 Photoimageable Covercoat Materials: Designed to provide uniform coverage in mass production applications, the Rogers' R/flex 8080 enables printed circuit board manufacturers to achieve ultra-fine, high precision etch patterns that have traditionally been unattainable through conventional screen printing. The photoimageable covercoat materials provide outstanding imaging resolution, flexibility and creaseability, as required for developing today's high-density flexible printed circuits.
Rogers Corporation
http://www.rogerscorp.com
This page has been viewed 190 times.
More from Rogers Corporation
December 9, 2009 - Corporate News
Rogers Introduces Poron Thinstik Soft Seal Foam Material
Rogers Corporation
October 14, 2009 - Corporate News
Rogers Corp. To Showcase Innovative Advanced Materials at Productronica
Rogers Corporation
September 15, 2009 - Corporate News
Rogers Corp Announces Introduction of RO4360 6.15 DK Laminates
Rogers Corporation
August 27, 2009 - Corporate News
Rogers Corp.To Display High Frequency Laminates at IPC Midwest & PCB West Shows
Rogers Corporation
July 24, 2009 - Corporate News
Rogers Corp. New RO4730 Laminates For Light, Low-Loss Antenna Designs
Rogers Corp.
May 13, 2009 - Corporate News
Rogers To Highlight Breakthrough UL Rating, Advanced Thermal Solutions at PCIM
Rogers Corporation
May 12, 2009 - Corporate News
Rogers Introduces Low-Z Axis Material For Airborne Antenna Applications
Rogers Corporation
May 11, 2009 - Corporate News
Rogers to Introduce New Product & Showcase HF Laminates at IEEE MTT-S
Rogers Corporation
May 8, 2009 - Corporate News
Rogers High Performance Foams Division To Highlight 2 Key Products At SAMPE
Rogers Corporation
May 5, 2009 - Corporate News
Rogers Corporation
April 23, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates at PCB East
Rogers Corporation
April 9, 2009 - Corporate News
Rogers New RT/DUROID Laminates Wins New Product Award
Rogers Corporation
April 8, 2009 - Corporate News
Rogers Introduces RO4000 LoPro Laminates
Rogers Corporation
April 7, 2009 - Corporate News
Rogers To Feature Printed Electronics, Illuminated Advertising Solutions at Printed Electronics
Rogers Corporation
March 30, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates At CTIA 2009
Rogers Corporation
March 17, 2009 - Corporate News
Rogers Corporation Showcases High Frequency Laminates At IPC APEX EXPO
Rogers Corporation
February 26, 2009 - Corporate News
Rogers To Feature Advanced Circuit Materials At iMAPS Conference & Exhibition
Rogers Corporation
February 25, 2009 - Corporate News
Rogers Corp. to Showcase High Frequency Laminates at Satellite 2009 EXPO
Rogers Corporation
February 10, 2009 - Corporate News
Rogers Issues New Selection Guide for its Bisco Silicone Materials
Rogers Corporation
December 10, 2008 - Corporate News
Rogers Corporation Issues Patent Infringement Complaint
Rogers Corporation
September 18, 2008 - Corporate News
Rogers Featrues Antenna Grade Materials at Antenna Show
Rogers Corporation
September 12, 2008 - Corporate News
Roger's Bisco L3-A Silicone on Track for INNOTRANS
Rogers Corporation
May 28, 2008 - Corporate News
IT Will be Rogers' World at MTT-S Atlanta
Rogers Corporation
May 14, 2008 - Corporate News
Rogers Corp. Launches Its E/bak™ Cushion Mounting Materials
Rogers Corporation
May 6, 2008 - Corporate News
Rogers Corp. Features R/bak SA 3000 Cushion Mounting Tapes
Rogers Corporation
To find more articles from Rogers Corporation, use the search form below.
