Wire Bond Process Control
Developments in wire bonding technology have aimed towards obvious requirements for increased speed & finer pitch. But two other problem areas need addressing: How can bond process be controlled to ensure optimized bonds of constant quality & how can bond quality be monitored and documented, reliably and non-destructively. Click to download...
F&K Delvotec Inc.
