White Paper Download Index
Using Argon Plasma to Improved Wire Bonding Performance
Commercially-available Argon plasma cleaning systems can be used for effectively cleaning Fluorine, organic, and metal oxide contamination from the surface of a variety of microelectronic wire bonding pads in order to measurably improve the performance and reliability of wire bonding...
March Plasma Systems
This page has been viewed 578 times.
