| February 10, 2009 | Circuitmart Directory Listing |
Crystek Introduces New Line Of Attenuators In Rugged SMA Housing Fort Myers, FL – Crystek Microwave has introduced a new line of attenuators, the Crystek CATTEN series. Ranging from 1 to 20 dB signal attenuation, Crystek’s CATTEN models are designed in a rugged SMA housing for easy in-line connection and operation in test equipment, RF lab use and other embedded applications. Every attenuator is made in the U.S.A. and subjected to rigorous quality testing before leaving the factory. The frequency of Crystek’s attenuators ranges from DC to 3GHz. These units provide 1W of power dissipation (0.5W for 15dB and 20dB models) and impedance of 50 Ohms. Tolerance matching is used to provide superior temperature tracking to individual components. The attenuator’s operating temperature range is -40 to +85C. Crystek’s CATTEN attenuators are available in-stock from catalog distributors for approximately $18 each. For additional pricing details, contact Crystek Corporation. Family datasheets are available for download at www.crystek.com. For more information, contact sales at Crystek Corporation, 12730 Commonwealth Drive, Ft. Myers, FL 33913. Tel: 800-237-3061 or 239-561-3311; Fax: 239-561-1025; E-mail: sales@crystek.com. Contact:Crystek Corporation http://www.crystek.com | |
