| February 2, 2009 | Circuitmart Directory Listing |
Essemtec Delivers First Series of Newly Developed RO-VARIO Reflow and Curing Ovens RO-VARIO, the new developed reflow and curing oven from Essemtec, offers a unique modularity and flexibility for a number of solder and hardness tasks in the electronics and solar engineering industries. The first ovens were delivered to the customers earlier this month. The first production series of the RO-VARIO, which is expandable up to 14 zones, sold out quickly. In addition to customers in Germany and Austria, companies from India purchased the unique oven. “This shows us that we are not only able to satisfy the requirements of the European customers with the technical concept of the oven, but that the oven will find purchasers in growth markets too. Our technical concept convinces the customers,” said Martin Ziehbrunner, manager of Essemtec AG. “Since the development of the RO-VARIO, oven modularity and flexibility have been the focus,” commented Joachim Biegel, RO-VARIO product manager. Apart from the number of heating and cooling zones the transport system also is designed in modular system. The RO-VARIO can be used as full convection reflow oven, IR curing oven with special slow forward feed or UV hardness system. Customers can choose various transport systems. Additionally, to a mesh belt, which has an operation width of 600 mm, the oven can be configured with pin chain drive or as chain over belt. Up to five separate tracks can be fed through the oven at the pin chain drive (e.g., for use in the solar industry or for parallel production of printing boards in a line production). The chain profiles also can be configured as center supports. Using a special shifting system, developed and patented for this use, it is ensured that all tracks and/or center supports will be adjusted individually and automatically to the various transportation widths. Absolute parallelism of the individual tracks is ensured for 14 zone ovens. In addition to the transport systems, the heating chambers have been redeveloped completely and have been equipped with numerous innovations. Highly efficient heat protection is used, ensuring the highest possible efficiency of energy. A manufacturing technique is used that rivets the heating chambers as opposed to welding them. This technique has proven successful under extreme conditions in other industrial sectors, particularly in the aerospace industry to avoid material tension by different temperatures. All heating chambers are floating mounted, allowing the chamber to expand without blocking or bending the frame, the cap or the transport system. The chambers only expand in a “controlled length and width. The complete frame of the cap can be opened parallel including the covering and the heating chambers. This enables easy access from the front and the back to the hearting chambers and the inside of the oven for cleaning and maintenance work. At the same time, RO-VARIO has a small footprint, key for companies with limited space. The driving system of the fans, placed outside of the “hot zone,“ is mounted on the heating chambers. By the use of the unique driving concept and the assembly of a cool environment, MTBF can be minimized by factors. The whole driving process is observed by a sensor that is placed at the driving system of the last chamber. “Just this feature as well as the easy maintenance of the oven and the appreciation resulting from it explain by customers have chosen the RO-VARIO”, Martin Ziehbrunner concludes. Contact:Essemtec Florian Schildein http://www.essemtec.com | |
