White Paper Submit Form
High Test Coverage to ensure best Quality
Plextek traditionally designs and manufactures boards of both low-medium value/high volume (i.e. batches of 10,000 boards) and high value/low volume (e.g. batches of 10 boards). In 2000 Plextek began using the Boundary Scan system from GOEPEL to check for shorts and opens, fault isolation and repair. The methodology was extremely useful for highly complex boards, especially during the integration stage. It helps to eliminate hardware manufacturing problems as a possible cause of any software issues that were seen. Before using Boundary Scan Plextek’s engineers would face uncertain and potentially lengthy integration times with unknown software and hardware.
GOEPEL electronic
This page has been viewed 818 times.
