White Paper Submit Form
A Next Generation Process for Moisture Sensitive Devices
The influence of humidity on the reliability of electronic components is generally underestimated and often simply unknown. Moisture sensitive devices (MSDs) are electronic components encapsulated with plastic compounds and other organic materials. Moisture from atmospheric humidity enters these permeable packaging materials by diffusion and collects at the interfaces of dissimilar material ...
Super Dry®
This page has been viewed 998 times.
