October 6, 2008
IR Reflow issue
We have an SMT package with J-bend leads that cracks and drops off at the shoulder of the package after IR Reflow solder.
What in the reflow process is causing these defects?
R. Y.
This "Ask the Experts" page has been viewed 346 times.
October 6, 2008
That sounds more like a component manufacturing issue rather than the reflow process. If your reflow is heating the component to the point of lead shoulder failure, the rest of the PCB would probably show signs of overheating as well.
Kris Roberson, Senior Technical Instructor
BEST, Inc.
kroberson@solder.net
Kris Roberson has experience as a machine operator, Machine and Engineering technician as well as an Electronics and Process Engineer for companies as Motorola, US Robotics. Kris has earned the highest Certifications awarded by the IPC in electronics training, being certified as an Master Instructor in IPC7711 / 7721, IPC A-610D and IPC J-STD 001D.
October 6, 2008
This sounds like a combination of a oxidized lead surface and a low thermal profile. Check the solderability of the parts through a lab that does wetting balance testing and then have someone assess the reflow profile for the mass of the board and parts. If these areas show okay then check for a barrier film on the J-leaded QFP leads.
Terry Munson, President/Senior Technical Consultant
Foresite
terrym@residues.com
Mr. Munson, President and Founder of Foresite, has extensive electronics industry experience applying Ion Chromatography analytical techniques to a wide spectrum of manufacturing applications. Terry is actively involved in the IPC and has served as session chair at technical seminars on contamination effects.
October 6, 2008
The black body of the part is a very good absorber of IR radiation. If you put a thermocouple on top of it, you should see how much hotter than the rest of your product it gets.
It is likely your part is overheating and the lead frame to overmold junction is being damaged due to melting and/or expansion related stresses.
Either that or you have some poorly made parts. If you get a different part with the same package type and it does not have the same problem, go back to your supplier with the problem.
John Vivari, Application Engineering Supervisor
EFD, Inc.
jvivari@efd-inc.com
Mr. Vivari has more than ten years of electronic engineering design and assembly experience and received his Masters of Industrial Manufacturing Engineering from the University of New Haven. His expertise in fluid dispensing and solder paste technology assists others in identifying the most cost effective method for assembling products.
October 6, 2008
Without having more detail it is difficult to diagnose the actual issue. With cracked or failed solder joints you would want to do a few things to determine the actual root cause. Is this a sudden issue?
In other words can it be related to a specific batch of components and/or PCBs? Take a look at the fracture surfaces, what do you see? Does it appear that the solder joint is just "pulling out" of the solder fillet (sometimes called "foot-in-mud"). If so it could be a plating issue on the components.
Is it fracturing at the pad surface? Could it be related to the metalization on the PCB? Those are some concerns to look into.
Since you are suspecting reflow issues, perform a profile, being sure to place a thermocouple adjacent to the solder joint in question. If this is a densely populated PCB, with components of different sizes you want to make sure you profile in multiple locations to make sure you have the proper reflow time and temperatures at each location.
Henkel Technologies
brian.toleno@us.henkel.com
Dr. Brian Toleno is the Application Engineering Team leader for Henkel Technologies. He is responsible for the technical service and application engineering for Henkel's electronics assembly materials, including solder paste, underfills, PCB protection materials, and underfills. He holds a Ph.D. in Analytical Chemistry from The Pennsylvania State University and a B.S. degree in Chemistry from Ursinus College.
October 6, 2008
This is suspicious, and a failure analysis should be undertaken. I would be guessing without examining the parts.
If you do not reflow the part to a pad but subject the part the same heating cycle, does this lead still break?
How flat is the board after reflow? The lead has to fail with stress so you need to answer where the stress is coming from.
Steven Adamson, Market Manager
Asymtek
sadamson@asymtek.com
Steven Adamson is a Market Manager with Asymtek and has worked for the company for 10 years. Prior to this he has worked for Kodak, Motorola and Plessey, ICL in the UK. Steve holds five US and 2 UK patents. He was awarded a HNC in electrical engineering from Stockport College of Technology. Adamson is 2008 President of IMAPS.
October 6, 2008
The following could be the possible reasons for this failure …..
- Board support in placement and the placement pressure. Too much pressure with direct support under the component could stress the package body.
- Since it is IR heating check to see if the package body is able to withstand the temperature setting for the IR panel. Possible damage occurring due to high temperature.
- Check if the component is lead free compatible if the process is lead free.
- Component age, handling and storage. Old components that have been in storage could have absorbed moisture over a period of time resulting in popcorn delamination. If this is the case try baking the components prior to assembly (125 deg. C for 48 hours would be good)
- Check the reflow profile to make sure there is no thermal shocking happening to the components.
- Also check to make sure that the cooling is not too rapid.
Bjorn Dahle, President
KIC
bdahle@kicmail.com
October 6, 2008
There are several contributing factors here.
A simple solution would be an evaluation of the volume of paste that is being deposited on the board.
It sounds like there could be a large deposit of solder that is working against your oven profile. If the solder deposit is extensive, and the joint cools too quickly, that could result in the crack that you are describing.
You should be able to contact your stencil vendor and work with them to determine how much paste would be required to properly solder the lead. With the proper volume and location of paste deposited, you may be able to avoid having to change the profile of the oven.
Michael Ray, President
mike@integratedideas.com
Mike Ray is founder and president of Integrated Ideas & Technologies, Inc., a manufacturer of SMT stencils located in Post Falls, Idaho. Mike Ray developed the first successful universal frame and holds patents on the AXIS laser system. Mike has served the SMT industry since the mid 1980's and the PC industry since 1978.
