Fort Myers, FL – Crystek's CVCO55CC-3366-3597 VCO (Voltage Controlled Oscillator) operates from 3366 MHz to 3597 MHz with a control voltage range of 0.1V~16V. This VCO features a typical phase noise of -106 dBc/Hz @ 10KHz offset and has excellent linearity. Output power is typically +5.0 dBm.
The model CVCO55CC-3366-3597 is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 8 V, with a max current consumption of 40 mA. Pulling and Pushing are minimized to 3.00 MHz and 0.50 MHz/V, respectively. Second harmonic suppression is
-20 dBc typical.
The CVCO55CC-3366-3597 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
Pricing for the CVCO55CC-3366-3597 will start at $19.52 ea. in volume. For additional pricing details, contact Crystek Corporation.
