September 26, 2008
Meets MIL-I-46058C Requirements
DYMAX Corporation, the leader in light-curing technology for electronic materials, announces that conformal coating Dual-Cure™ 9481 has met the requirements of MIL-I-46058C and IPC-CC-830B. Dual-Cure 9481 is solvent free and is specifically formulated for rapid cure when exposed to UV and/or visible light. Its ability to cure in seconds enables faster processing, greater output, and lower assembly costs. Ambient moisture will cure areas shaded from light over time. The material has low surface energy to ensure wetting on circuitry, processing materials and components. Viscosity is optimized for application of .001 - .003" coating thickness by industry standard spray systems. Dual-Cure 9481 fluoresces blue when exposed to black light for rapid quality control inspection of coated areas.
DYMAX Corporation is a leading technology-based company specializing in the formulation, manufacture and service of advanced assembly adhesives, coatings, epoxies, masking resins, and light curing systems.
For more information, contact DYMAX Corp., 318 Industrial Lane, Torrington, CT 06790; Phone: 860-482-1010; Fax: 860-496-0608; Toll Free: 1-877-DYMAX-UV (1-877-396-2988); e-mail: info@dymax.com.
DYMAX Corporation
http://www.dymax.com/
This page has been viewed 155 times. |
More from DYMAX Corporation
December 1, 2008 - Corporate News
Dymax Debuts New, Highly Functional Website
Dymax Corporation
November 26, 2008 - Corporate News
DYMAX Plastics Bonding Adhesive Has Built-in Cure Indicator
DYMAX
DYMAX Corporation
November 13, 2008 - Corporate News
New Dymax ACCU-CAL™ 50V Visible Radiometer
Dymax Corporation
DYMAX - One of the Fastest-Growing Companies in the U.S.
DYMAX Corporation
October 23, 2008 - Corporate News
DYMAX + PARTNER PAK = Sustainable Clamshell Packaging Technology
DYMAX
October 22, 2008 - Corporate News
DYMAX Plastic-Bonding Adhesives Pair Well with New BlueWave® LED Spot Curing System
DYMAX Corporation
DYMAX Acquires Dispensing Leader Tridak
DYMAX Corporation
September 26, 2008 - Corporate News
DYMAX Corporation
September 25, 2008 - Corporate News
DYMAX
September 24, 2008 - Corporate News
New DYMAX ACCU-CAL™ 50V Visible Radiometer
DYMAX
DYMAX
New Moisture-Resistant Gasketing Resin from DYMAX
DYMAX Corporation
July 28, 2008 - Corporate News
DYMAX BlueWave LED System Now CE Marked for Global Distribution
DYMAX
DYMAX Corporation
July 14, 2008 - Corporate News
DYMAX Introduces Fluorescing Light-Curing Needle Bonding Adhesive
DYMAX Corporation
July 11, 2008 - Corporate News
Fluorescing Light-Curing Needle Bonding Adhesive from Dymax
DYMAX Corporation
June 6, 2008 - Corporate News
New Conformal Coating from DYMAX Meets MIL-I-46058C and IPC-CC-830B Requirements
DYMAX Corporation
May 8, 2008 - Corporate News
New Conformal Coating from DYMAX Meets Requirements
DYMAX Corporation
May 7, 2008 - Corporate News
Mr. Kyle Rhodes Joins DYMAX as Medical Market Segment Manager
Dymax
May 6, 2008 - Corporate News
Mr. Terrence Woldorf Joins DYMAX Corporation's Sales and Marketing Team
DYMAX Corporation
April 16, 2008 - Corporate News
Get Cool, Consistent, Visible Light Curing with New DYMAX BlueWaveTM LED System
DYMAX Corp.
180° Curing w/ New DYMAX UVCS SideCure™ Conveyor System
DYMAX Corp.
April 14, 2008 - Corporate News
Rob Kleinschmidt Joins DYMAX as Sales Engineer
DYMAX Corporation
April 10, 2008 - Corporate News
DYMAX Introduces See-CureTM Technology
Dymax
To find more articles from DYMAX Corporation, use the search form below.
