Having Trouble with Profiling? Cutting-edge reflow profiling kit
Heller is pleased to release its much anticipated reflow profiling kit. The leader in oven technology is now a leading provider of profiling technology. The reliability and ease-of-use you've come to expect from Heller, in a profiling kit. Learn more
Heller Industries
Exclusive
IPC Midwest Show Report
The venue for this years IPC Midwest show is the Renaissance Hotel and Convention Center in Schaumburg, Illinois. It is a beautifully architected site and seems to be custom built to manage a conference of this size. It is bright and open and the original art that hangs ...
Steve DeCollibus, Managing Editor
Circuitnet
IPC/JEDEC Technical Conference Transitioning to Lead Free
Meeting the requirements of RoHS compliance and successfully implementing lead-free electronics assembly processes is an ongoing challenge for the industry. Find new strategies for implementation at IPC/JEDEC's conference on Transitioning to Lead Free, December 8-10 2008 in Dallas, TX. Register by November 21, 2008 and SAVE 10%. IPC/JEDEC
Simple Nature EZReball Reballing Process Allows Technician to Re-add Balls
Alignment is simple, eliminating the need to buy custom frames. The adhesive holds the balls firmly in place reducing the problem of missing solder balls found in other techniques. After the device has been reflowed, the preform is simply peeled off. BEST Inc.
EFD(R) Introduces New Cartridges for Lead-Free Solder Dispensing
EFD, Inc. announces the addition of new green-colored cartridges to their OptimumTM line of industrial fluid dispensing components. International ...
EFD
New RFID reader makes manual track & trace of garments easier
Datamars has expanded its RFID reader portfolio with the launch of the new high-frequency Mid-Range reader "R-IN1300 MID" ideally suited to ...
Datamars
Pickering Interfaces Introduces New LXI Video Multiplexer
Pickering Interfaces is expanding its range of LXI switching solutions with the introduction of a 72 channel 75 ohm 1GHz multiplexer. The ...
DYMAX Corporation is pleased to introduce a new tack-free, soft gasket material for sealing fuel cells, appliance housings, and critical ...
DYMAX
IRphotonics Launches World's First Thermal Spot Curing System
IRphotonics launched a new type of thermal spot curing system, branded under the name iCure™. The first product available in the Series, the ...
IRphotonics
iSuppli's FID 2008 to Bring Together World's Leading Display Experts
iSuppli Corp. is pleased to announce its 2008 Flat Information Displays (FID) Conference, the leading event for the global display industry, ...
iSuppli Corporation
Balver Zinn Speeds Customer Interaction with Updated Web Site
Balver Zinn announces the launch of an updated Web site, http://www.balverzinn.com/, designed to enable complete interaction ...
Balver Zinn
Worldwide hardware protection - A new idea for protection against product piracy
The constantly growing number of illegal reproductions, plagiarisms and pirate copies of electronic products and machines shows that their ...
Lackwerke Peters GmbH
SMTA Nutmeg Vendor Show & Technical Program
The Nutmeg Chapter invites you to spend the day at this upcoming event featuring exhibiting companies, networking opportunities, technical ...
SMTA
Transition Automation Appoints Loriot Industrial Company, Ltd. as Vietnam Distributor
Transition Automation, Inc. the worldwide leader in the manufacturing and distribution of Permalex® Edge Metal Squeegees, holder systems, and ...
PoPs Made Easy New White Paper
Find out how with Henkel's new Epoxy Flux material offering underfill protection. Click to download paper
Henkel Corporation
