Steven Adamson |
No. 52777 |
Market Specialist
Nordson ASYMTEK
steven.adamson@nordsonasymtek.com
Steven Adamson is Market Specialist for Nordson ASYMTEK. He has worked for Kodak, Motorola and Plessey, ICL in the UK. He holds five US and 2 UK patents, was awarded a HNC in electrical engineering and was 2008 President of IMAPS.
Experts Questions Answered by Steven Adamson
Aug 23, 2010 |
Post Print Inspection Issue
Aug 9, 2010 |
Flux Residue Causing Test Issues
Aug 9, 2010 |
Solder Mask Contributing To Solder Balls
Jul 19, 2010 |
Gold Plated Lead Discoloration
Jun 28, 2010 |
Through Hole Component Phase Out
Jun 21, 2010 |
Component Storage Recommendations
May 24, 2010 |
Humidity Inside Our Screen Printer
May 24, 2010 |
Lead-Free Profile on Tin/Lead Assemblies
May 10, 2010 |
Can Water be Harmful to Electronics Components?
Apr 26, 2010 |
How To Mask Areas During Conformal Coating
Apr 26, 2010 |
Organic Flux Residue Concerns
Apr 5, 2010 |
Lead-free Assemblies Reworked with Leaded Solder
Apr 5, 2010 |
Cause of Pin Hole Rejects
Mar 29, 2010 |
Do We Need to Conformally Coat Edges?
Mar 22, 2010 |
Soldering lead-free component, with tin-lead solder
Mar 8, 2010 |
Re-plating lead-free components for tin/lead assembly
Mar 8, 2010 |
Contamination Prior to Conformal Coating
Mar 1, 2010 |
When Should We Use Underfill?
Feb 8, 2010 |
Leadless Component Hand Soldering Help
Feb 1, 2010 |
BGA Shifting During Reflow
Jan 17, 2010 |
Epoxy Bonding Problems on RoHS Boards
Dec 14, 2009 |
Contamination from Cigarette Smoking
Dec 7, 2009 |
SMT Component Lead Oxidation
Nov 23, 2009 |
Concerns Using Hand Sanitizers
Nov 23, 2009 |
Cause of Yellow/Brown Discoloration
Oct 27, 2009 |
Tacky Flux Residue Problem
Oct 5, 2009 |
Affects of Silicone Migration
Sep 28, 2009 |
Solder Joint Explosions
Sep 28, 2009 |
Spray Fluxer Uniformity Question
Sep 14, 2009 |
Hard Water Contamination
Aug 31, 2009 |
Mysterious Solder Balls
Aug 24, 2009 |
Delamination dilemma
Aug 10, 2009 |
Need for SMT adhesives
Jul 6, 2009 |
How to predict possible intermetallics
Jun 22, 2009 |
Ultrasonic Cleaning Causing Damage
Jun 15, 2009 |
What is the Proper DI Water Resistivity
Jun 10, 2009 |
Recertify PCB's past their shelf life
May 26, 2009 |
Which term to use, PWB or PCB?
May 26, 2009 |
Difference between shiny and matt solder resist
Apr 13, 2009 |
Exposed Copper on Gold Plated Conductors
Mar 30, 2009 |
Alternative to Conformal Coating
Mar 9, 2009 |
How to bond heavy component to PCB
Feb 16, 2009 |
Conformal coating and connector holes
Dec 22, 2008 |
Procedure for Baking Flexible Circuits
Dec 14, 2008 |
IPA cleaning precautions
Dec 10, 2008 |
Conformal Coating Process
Nov 24, 2008 |
Solder Bump QFN's
Nov 24, 2008 |
Define Blow Holes
Nov 3, 2008 |
Idle Time Between Soldering and Cleaning
Nov 3, 2008 |
Lifecycle Standards
Oct 27, 2008 |
Adhesive for sensor attachment
Oct 13, 2008 |
Solder to a thin flexible circuit
Oct 13, 2008 |
Substance causing open BGA solder joints
Oct 6, 2008 |
Oxidation on pads causes poor solder joints
Oct 6, 2008 |
IR Reflow Issue
