Maynard, MA. - Orchid Technologies Engineering & Consulting, Completes the Development of a High-speed AdvancedTCA Carrier Blade Design based on a Freescale Power-PC MPC8548 supported by 400MHz DDR2 RAM design.
The AdvancedTCA Carrier Blade electronics design demands the most from any engineering team. The 32-bit, 1.3 GHz processor with 48 lanes of PCI Express peripheral support and fat-pipe I/O support is a performance champion. The design also has customized Zone 3 RTM connectivity. In addition, Renasas SH8-based IPMI resource management supports over 200 Watts of on-board hot-swap power control making this ATCA Blade highly reliable.
"AdvancedTCA and microTCA architectures are intended for demanding, high availability applications," says Paul Nickelsberg, President and Senior Engineer at Orchid Technologies. "Orchid's early success with AdvancedTCA and microTCA design provided our clients world-class high-end computing options."
