Corporate News Index
September 17, 2008
Aqueous to Highlight the Trident Automatic Defluxing System at IPC Midwest
RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces that it will exhibit the Trident, its fourth-generation automatic defluxing system, in booth 411 at the upcoming IPC Midwest Conference & Exhibition, scheduled to take place September 24–25, 2008 at the Renaissance Schaumburg Hotel & Convention Center.
http://www.aqueoustech.com
This page has been viewed 82 times.
More from Aqueous Technologies
August 26, 2008 - Corporate News
Aqueous Technologies’ Trident Automatic Defluxing System Wins a 2008 Global Technology Award
Aqueous Technologies to Debut the SMT3000LD Automatic Defluxing System at Nepcon South China
August 5, 2008 - Corporate News
Aqueous Technologies to Debut the Trident III Automatic Defluxing System at SMTAI
Aqueous Technologies Trident Automatic Defluxing System Wins Two 2008 Advanced Packaging Awards
May 19, 2008 - Corporate News
Aqueous Technologies to Premier the Trident Automatic Defluxing System at SMT Nuremberg
May 8, 2008 - Corporate News
Aqueous Technologies Introduces New Financing Offer
April 21, 2008 - Corporate News
Aqueous Technologies Wins an EMAsia Innovation Award
Aqueous Technologies C3 Cleanliness Tester Wins VISION Award
April 11, 2008 - Corporate News
Aqueous Technologies’ Trident Automatic Defluxing System Named as a Two-Time First Finalist for the VISION Awards
April 9, 2008 - Corporate News
Aqueous Wins Industry Award for Its Trident Automatic Defluxing System
Aqueous Technologies to Display Zero-Ion Contamination Tester at APEX
March 25, 2008 - Corporate News
Aqueous Tech to Showcase Trident Automatic Defluxing Systems at APEX
March 24, 2008 - Corporate News
Aqueous Technologies to Highlight StencilWasher-ECO at APEX
March 18, 2008 - Corporate News
Aqueous Technologies to Feature C3 Cleanliness Tester at APEX
March 12, 2008 - Corporate News
Aqueous Technologies to Display StencilWasher-CLR at APEX
January 8, 2008 - Corporate News
Aqueous Technologies Appoint Accelonix as Distributor
January 3, 2008 - Corporate News
Aqueous Announces 3rd Installment in E-Learning Presentation
To find more articles from Aqueous Technologies, use the search form below.
