September 9, 2008
Essemtec Introduces FLX2010C System
Vacuum Downholder for Flex Board Component Placement
Essemtec AG, a leading manufacturer of surface mount technology production equipment, announces that it has worked with leading suppliers of die bonders to develop a highly economical solution for the efficient placement of special components on film or flex boards, providing many benefits to the users.
The new machine concept is based on the FLX2010C, the capable forerunner of the currently introduced FLX2011. The placement solution features a conveyor system that allows for flexible and fast placement operations on the substrate. The substrate itself, a sandwich piece consisting of an aluminum carrier with the film and downholder, will be located on the conveyor and moved into the placement position.
The FLX2010C can be placed upstream in the line before a die bonder, which dispenses adhesive and places the chips on the substrate. In a downstream pick-and-place process, the special components will be accurately placed on these dice, where the sandwich carrier will be inserted from the left side and stopped by means of a "stopin" mechanism. The carrier is located securely with a chuck. Nozzles suck in from the underside of the sandwich carrier at defined positions in order to prevent shifting during the subsequent placement operation. As a result, the film substrate can be populated from conventional component feeder systems after the alignment of the fiducials. The film leaves the placement machine via the conveyor after the release of the sandwich carrier from the vacuum for the next process step to follow.
The FLX2010C provides users with numerous benefits over other machine solutions. The equipment, based on Essemtec’s highly flexible, modular standard placement module FLX2010C, provides excellent accuracy and durability. The basis of the platform is that a standard placement system can be used even for the design of this special purpose machine. There are more than 500 of these modules in operation worldwide.
Essemtec
Adrian Schärli
http://www.essemtec.com
This page has been viewed 104 times. |
More from Essemtec
Essemtec
November 12, 2008 - Corporate News
Automatic SMD Insertion of Silicone Keys
Essemtec
October 9, 2008 - Corporate News
Essemtec to Exhibit at Mexitrónica
Essemtec
October 1, 2008 - Corporate News
Essemtec Opens New Demo and Training Center in Suzhou, China
Essemtec
September 23, 2008 - Corporate News
ESSEMTEC to Exhibit SP003-MLV at IPC Midwest
Essemtec
ESSEMTEC to Display RO300FC-C at IPC Midwest
ESSEMTEC
ESSEMTEC to Introduce SP150 at IPC Midwest
ESSEMTEC
ESSEMTEC to Feature EXPERT-SAFP Prototyping Station at IPC Midwest
Essemtec
ESSEMTEC to Display New Placement Machine at IPC Midwest
ESSEMTEC
ESSEMTEC to Premier FLX2011 to North American Industry at IPC Midwest
ESSEMTEC
Essemtec
Essemtec Introduces Semi-automated Paste Printer Features
Essemtec
Essemtec Premiers Automated Printer with Sideways Moving Loading Drawer
Essemtec
ESSEMTEC Wins Global Technology Award for Multi-Flexible Production Solution
Essemtec
Essemtec provides even more customer benefits with enlarged service portfolio
Essemtec
August 20, 2008 - Corporate News
Essemtec's Placement Machine for Flex Board and Film Substrate Features Twin Vacuum Table
Essemtec
Essemtec to Highlight SP003-MLV Semiautomatic Stencil Printer with Vision at NEPCON South China
Essemtec
August 15, 2008 - Corporate News
Essemtec Introduces Semiautomatic Printer
Essemtec
ESSEMTEC to Highlight SP003-MLV at SMTAI
ESSEMTEC
New placement machine for small to middle-sized production volumes from ESSEMTEC at NEPCON South China
Essemtec
August 13, 2008 - Corporate News
ESSEMTEC to Exhibit RO300FC-C at SMTAI
ESSEMTEC
ESSEMTEC to Feature EXPERT-SAFP Prototyping Station at SMTAI
Essemtec
Essemtec Introduces Semiautomatic SMT Prototyping System at NEPCON South China
Essemtec
August 7, 2008 - Corporate News
Essemtec Introduces Updated Web Site
Essemtec
August 6, 2008 - Corporate News
ESSEMTEC to Display New Placement Machine for Small and Mid-Size Production at SMTAI
Essemtec
To find more articles from Essemtec, use the search form below.
