Corporate News Index
August 28, 2008
Juki Wins a 2008 Global Technology Award for Its OPASS Technology
MORRISVILLE, NC - Juki Corporation, a world-leading provider of automated assembly products and systems, announces that its OPASS technology won a Global Technology Award in the Software category. The award was presented by Global SMT & Packaging Magazine’s Publisher and Editor-in-Chief Trevor Galbraith during a Tuesday, August 19, 2008 ceremony that took place during the SMTA International exhibition and conference in Orlando, FL.
With OPASS technology, the placement machine can automatically detect and compensate for misalignment of the solder paste to produce high-quality boards regardless of the process errors beforehand.
“The OPASS system developed by Juki ensures that customers can achieve high first-pass yields regardless of circuit pattern variations between board lots,” said Bob Black, CEO.
While board makers strive to keep variations between lots to an absolute minimum, it is not possible for them to eliminate forward expansion and scaling completely. This means that the pads are not exactly in the same positions as they were on the previous lot. When the boards are fed into the stencil printer for solder paste there can be slight offsets from the solder paste print to the pad location. In larger parts that can be a very small percentage of the pad size, but in smaller parts like 01005, 0201 or even 0402, the solder could be halfway off of the pad.
Likewise with ceramic or flexible boards, print repeatability can be difficult to achieve, causing further solder paste alignment problems. There also is cause for concern on double-sided boards because boards tend to contract after the first side reflow process. With the increased use of lead-free solder, the properties of the self-alignment effects have changed.
Through extensive research and cooperation with high-volume manufacturers, Juki has found that placing small components centered on the paste and not the pad will reduce the defect rate. OPASS addresses this issue.
When OPASS is integrated into the electronics assembly machine, it eliminates the need for other equipment such as AOI machines to correct for solder paste alignment problems and provides a comprehensive solution to meet the future market trends of component miniaturization, high-density placement and lead-free assembly.
“The OPASS technology demonstrates Juki’s innovation in providing solutions in SMT assembly. While others have announced links with solder paste inspection systems and AOI systems costing $100K to $150K to address this issue, Juki has developed an in-machine solution costing less than $15K,” said Black.
The Global Technology Awards program is sponsored by Global SMT & Packaging Magazine, and is an annual celebration of product excellence in semiconductor packaging and electronics assembly. Premier products based on the finest examples of creative advancement in technology in key areas are chosen by a distinguished panel of global industry experts.
Juki Automation Systems
Geron Ryden
http://www.jas-smt.com
This page has been viewed 144 times.
More from Juki Automation Systems
December 19, 2008 - Corporate News
Juki Holds Three Christmas Parties for Employees Across the U.S.
October 14, 2008 - Corporate News
Juki Releases FX3 High-Speed Modular Mounter for High-Volume Circuit Board Assembly
Juki Corporation
October 3, 2008 - Corporate News
Juki Automation Systems, Inc. Announces Record Growth
Juki to Feature the 350 Selective Soldering System at IPC Midwest
Juki Corporation
Juki to Highlight FX-1RL at IPC Midwest
Juki Corporation
Juki Automation Systems to the Exhibit KE-2080 at IPC Midwest
August 29, 2008 - Corporate News
Juki Placement Systems 'Pump up the Volume' at Olympics
Juki Corporation
August 28, 2008 - Corporate News
Juki Corporation Wins a Global Technology Award for Its FX-3 Chip Shooter
Juki Corporation
August 18, 2008 - Corporate News
Juki Announce Appointment of Southwest Systems Technology
Juki Automation Systems to the Display KE-2080 at SMTAI
Juki Corporation
August 6, 2008 - Corporate News
Juki to Exhibit New 350E Selective Soldering System at SMTAI
Juki Corporation
June 9, 2008 - Corporate News
Juki Introduces Updated High-Speed Dispensing System
Juki Corporation
May 2, 2008 - Corporate News
Jukis' Bob Black Appointed to IPC's Global Board of Directors
Juki
May 1, 2008 - Corporate News
Juki Receives Five Prestigious Global Industry Awards
Juki
April 30, 2008 - Corporate News
Juki to Feature FX-1R at Nepcon East 2008
Juki
April 29, 2008 - Corporate News
Juki Automation Systems to Showcase IFS-X2 Intelligent Feeder System at Nepcon East
Juki
April 28, 2008 - Corporate News
Juki to Premier New 350E Selective Soldering System at Nepcon East 2008
Juki
April 25, 2008 - Corporate News
Juki Automation Systems to the Exhibit KE-2080 at Nepcon East 2008
Juki
April 11, 2008 - Corporate News
Jukis' OPASS Receives VISION Award First Finalist Recognition
Juki
April 9, 2008 - Corporate News
Juki Wins a 2008 NPI Award for Its OPASS Technology
Juki Automation
April 8, 2008 - Corporate News
Juki Wins a 2008 NPI Award for Its 350 Selective Soldering System
Juki Corporation
April 4, 2008 - Corporate News
Juki to Premier FX-3 Chip Shooter at NEPCON China, Shanghai
Juki Corporation
Juki Automation Systems to Exhibit KE-2070 at APEX
Juki Corporation
March 25, 2008 - Corporate News
Juki Automation Systems to the Display KE-2080 at APEX
To find more articles from Juki Automation Systems, use the search form below.
