RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces that Trident, its fourth-generation automatic defluxing system, won a Global Technology Award in the cleaning equipment category. The award was presented by Global SMT & Packaging Magazine’s Publisher and Editor-in-Chief Trevor Galbraith during a Tuesday, August 19, 2008 ceremony that took place during the SMTA International exhibition and conference in Orlando, FL. The Trident Series represents the next generation of lead-free compatible, fully automatic post-reflow defluxing systems.
The Global Technology Awards program is sponsored by Global SMT & Packaging Magazine, and is an annual celebration of product excellence in semiconductor packaging and electronics assembly. Premier products based on the finest examples of creative advancement in technology in key areas are chosen by a distinguished panel of global industry experts.
