Fort Myers, FL, August 14, 2008 – Crystek's CVCO55FL-0136-0174 VCO operates from 136 MHz to 174 MHz with a control voltage range of 0.5V~4.5V. This VCO features a typical phase noise of -123 dBc/Hz @ 10KHz offset and has excellent linearity. Output power is typically +9.0 dBm.
The model CVCO55FL-0136-0174 is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 5 V, with a max current consumption of 25 mA. Pulling and Pushing are minimized to 0.50 MHz and 0.50 MHz/V, respectively. Second harmonic suppression is -20 dBc typical.
The CVCO55FL-0136-0174 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
Pricing for the CVCO55FL-0136-0174 will start at $17.62 ea. in volume. For additional pricing details, contact Crystek Corporation.
Family datasheets are available for download at www.crystek.com. For more information, contact sales at Crystek Corporation, 12730 Commonwealth Drive, Ft. Myers, FL 33913.
