Corporate News Index
August 18, 2008
New Littelfuse 0501 Series Surface-Mount Fuse
with High Current Ratings and High Temperature Capability Provides Reliable DC-to-DC Converter and Voltage Regulator Module Circuit Protection
New 0501 Series fuse provides high operating current surge protection at working temperatures up to 150ºC
DES PLAINES, IL -  Littelfuse, Inc. (NASDAQ/NGS:LFUS), today introduced the 0501 Series surface-mount 1206-size fuse, specifically designed to provide fast-acting protection for high-current voltage regulator modules and DC-to-DC converters.
With an ultra high interrupt rating of 150A at 24VDC, the 0501 Series fuse provides circuit protection against short-circuit current surges. Unlike comparable fuses, the 0501 Series has a temperature rating 20 percent higher than its closest competitor. The new fuse operates effectively in temperatures ranging from -55ºC up to 150ºC without nuisance tripping.
The 0501 Series fuses meet the growing need for circuit protection in voltage regulator modules and DC-to-DC converters. Voltage regulator modules and DC-DC converters are used in an array of electronic devices, many which rely upon batteries as their primary power source. Voltage regulator modules ensure the correct voltage is supplied to microprocessors. DC-to-DC converters ensure that adequate voltage is available, even as the battery is depleted.
The 0501 Series fuses, which are low resistance devices, have the lowest internal cold resistance available to date. The 0501 Series operates reliably over a wide temperature range and, by keeping power loss at a minimum, ensures that applications will provide best possible performance. Furthermore, due to its robust load rating, the 0501 Series effectively minimizes nuisance trips during momentary overload conditions.
The 0501 Series is available in current ratings of 15A and 20A, both with a maximum fault current rating (Interrupt Rating) of 150A, which allows this series of fuses to be used in a wide array of applications. The 0501 Series is 100 percent lead-free, halide-free, compliant with RoHS requirements, and includes UL and CSA agency approval.
Littelfuse has over 80 years of experience in building and supplying over-current protection products. By coupling a comprehensive range of products and solutions with application expertise and support, Littelfuse demonstrates its dedication to providing protection that meets customers' needs in any electronic application.
Availability
0501 Series fuse samples are available now for order and sample request through authorized Littelfuse distributors worldwide. For a listing of Littelfuse distributors, please visit www.littelfuse.com.
Littelfuse, Inc.
Dan Stanek
http://www.littelfuse.com
This page has been viewed 115 times.
More from Littelfuse, Inc.
Littelfuse
New Littelfuse 477 Series Offers Highest AC/DC Fuse Ratings in 5x20mm Size
Littelfuse, Inc.
New Littelfuse Introduces Reliable, Low-Cost Open LED Protector
Littelfuse, Inc.
New Littelfuse 458 Series Nano2® Surface Mount Fuse
Littelfuse, Inc.
August 18, 2008 - Corporate News
Littelfuse, Inc.
August 12, 2008 - Corporate News
Littelfuse Introduces Ultra-low Capacitance SP3000 Series Silicon
Littelfuse, Inc.
To find more articles from Littelfuse, Inc., use the search form below.
