Speedline Electrovert
TYPE:- Electra 500 IF
SERIAL NUMBER – 11878573
ELEC - 8-1701-005-07-6
DATE - 12/99
VOLT- 480 PH-3
KVA- 83 5 HZ-60
MAX LINE AMPERAGE- 100 4 AMP
LARGEST MOTOR LOAD – 15 2 AMP
SHORT CIRCUIT MOTOR CAPACITY- 100000 AMS
MADE IN USA – 2-4013-111-03-3
PROG- VER. – 3.10 ( WINDOWS BASED )
BOTTOM HEATER – 3
TOP IR HEATER – 1 ( 12000W/480V )
FLUXER TYPE – FOAM FLUXER/SPRAY FLUXER(TWO)
WE USE ALPHA-373 Neutral water soluble flux.
Flux type- organic acid
Additional Info: Pictures and price on request
