August 12, 2008
Littelfuse Introduces Ultra-low Capacitance SP3000 Series Silicon
Protection Arrays for High Speed Data Lines and Interfaces
DES PLAINES, IL - Littelfuse, Inc. announced its SP3000 Series of electrostatic discharge (ESD) overvoltage suppression devices for data lines and interface circuits in a broad range of equipment. Applications include PCs and PC peripherals, hand-held devices, adapter cards, and data communications equipment - including USB2.0 and IEEE1394 devices.
This new series uses a steering diode architecture with an integral zener diode, fabricated with silicon avalanche technology, that protects each I/O line by routing potentially destructive surge currents to ground. The steering diodes reduce the overall off-state capacitance to an ultra-low level, which is also more stable with variations in signal voltage and frequency than typical ESD protection devices. The result is high-level protection with minimal distortion at data rates up to 1GHz or higher.
The SP3000 Series provides protection against ESD surges up to ±12kV when tested in accordance with IEC61000-4-2. Each device has a response time of less than 1ns and can handle surge currents up to 4.5A (8x20µs waveform), protecting up to four-lines (or pins) operating at 6VDC or lower. Leakage current is less than 0.5µA. They come in surface mount SC70, MSOP10, SOT553 and SOT563 packages to meet OEM demands for high component density and efficient tape-and-reel installation. All are RoHS (Restrictions On Hazardous Substances) compliant (lead-free/Green), and available in reel pack quantities of 3000 or 5000, depending on specific part number.
Availability. OEM samples of the SP3000 Series are available from stock. Tape and reel orders typically ship 8-10 weeks ARO.
Additional Information. For More Information on the SP3000 Series and any of the Littelfuse broadband circuit protection products, please visit the Littelfuse web site or contact your Littelfuse products representative of the Littelfuse Technical Support line at 1-800-999-9445.
SP3001 product specifications
SP3002 product specifications
SP3003 product specifications
Littelfuse, Inc.
http://www.littelfuse.com
This page has been viewed 96 times. |
More from Littelfuse, Inc.
Littelfuse
New Littelfuse 477 Series Offers Highest AC/DC Fuse Ratings in 5x20mm Size
Littelfuse, Inc.
New Littelfuse Introduces Reliable, Low-Cost Open LED Protector
Littelfuse, Inc.
New Littelfuse 458 Series Nano2® Surface Mount Fuse
Littelfuse, Inc.
August 18, 2008 - Corporate News
New Littelfuse 0501 Series Surface-Mount Fuse
Littelfuse, Inc.
August 12, 2008 - Corporate News
Littelfuse, Inc.
To find more articles from Littelfuse, Inc., use the search form below.
