DYMAX Corporation is pleased to announce a new moisture-resistant gasketing resin for sealing electrical conduit boxes, appliance housings, and critical electronic assemblies and devices. Ultra Light-Weld® GA-111 is a UV/Visible light-curable form-in-place (FIP) gasket developed for applications requiring low compression set, tack-free surface, and durable, reliable sealing. It is a soft gasket material with high adhesion to metals while providing a barrier to prevent absorption or penetration of air, dust, moisture, liquids and gaseous substances.
This gasketing material can be dispensed into intricate and complex configurations with the benefit of in-line curing which allows for increased production speed, greater output, lower processing costs, and reduced inventories. It is a one-part resin, requiring no mixing. GA-111 is low out-gassing, cures in seconds, and its viscosity allows for varying bead heights.
DYMAX FIP gaskets cure completely in seconds even in 1/4”-thick beads. No more racking, stacking, waiting, and un-racking as required with traditional FIP gaskets. DYMAX light-curing FIP gaskets offer the ultimate in gasket design flexibility. Designed for flat flanges or wide shallow grooves, permanent FIP gaskets can eliminate the delay experienced with slow-curing resins as well as the design, inventory, and labor expense associated with pre-cut gaskets. DYMAX gaskets cure faster and deeper than UV silicone, and do not release corrosive chemical by-products upon cure.
DYMAX Corporation is a technology-based company specializing in the formulation, manufacture and service of advanced assembly adhesives, coatings, epoxies, masking resins, and light-curing systems.
