Corporate News Index
August 14, 2008
New placement machine for small to middle-sized production volumes from ESSEMTEC at NEPCON South China
Essemtec is to showcase the new PANTERA–XV SMD placement machine in booth 2A05 at the upcoming NEPCON/EMT South China exhibition and conference - scheduled to take place August 26 - 29, 2008, at the Shenzhen Convention & Exhibition Center in Shenzhen, China.
The new PANTERA–XV SMD placement machine is designed to directly address prototyping and production runs in middle-sized quantities. The multi flexible PANTERA-XV is the culmination of two highly successful placement machines - the FLX2010 and the CSM7100-V, combining the best from both machine “families”: higher placement accuracy and speed, broader application range, high reliability and very low maintenance costs, as well as very short changeover time and excellent cost-performance ratio.
The PANTERA–XV placement machine handles the entire SMD range from 0201s up to 50 x 50mm QFPs with a fine pitch of 0.4mm. Designed especially for the assembly of complex printed boards and for fast changeover procedures, the machine offers a large number of feeder slots (up to 108), in a remarkably small footprint of less than 1 sqm. All intelligent tape and stick feeders will be recognized automatically regardless of the feeder slot being used, this provides for a very fast and error-free changeover process. The tape feeders are motorized and the transport speed is programmable and 0201 components can be reliably placed with a placement speed rated up to 4500 cph.
A further highlight is the even higher equipment precision, provided by the application of more accurate measuring systems. The resolution of the magnetic linear measuring system is 1 micron and the mechanism is not prone to dirt particles and dust and therefore provides high reliability and accuracy. For alignment, an integrated laser system measures small ICs and chip components "on the fly", anc for fine-pitch ICs or BGAs a bottom-up vision system is used. Additionally, another vision system can be installed for the automated correction of PCB positions, as well as for the teach-in of component locations.
The PANTERA–XV placement machine can be exactly tailored to match the assembly task by a multitude of options. Just one example of many is the optional dispensing system for solder paste and adhesive which helps to reduce the costs for stencils in prototyping and also allows for higher flexibility. A further example of the optional flexibility is the exchange of the universal standard magnetic PCB holder system for a fast inline transport system, needed for the assembly of larger board quantities.
Usage and programming can be learned quickly as the graphic-based software concept supports an extremely easy machine operation. Also, the programming of tasks is very simple: CAD data of layout software can be directly converted in an appropriate assembly program. In the case that such a data set is not available, the components can be manually placed (i.e. virtually) by means of the integrated camera system and this way the placement position be identified.
The PANTERA–XV SMD placement machine is especially designed for the flexible assembly of small and middle-sized production volumes. With its solid construction and high reliability the equipment can efficiently be used for larger production quantities.
With this machine customers also have access to Essemtec’s remote maintenance system and MyEssemtec.com user portal on the worldwide web. Another important item for the customers’ decision and production planning is the save-investment program: in the event that production requirements might change over time, Essemtec guarantees a fair price for the used machine, based on its age, in return for a faster piece of equipment. The existing assembly programs can still be used and also the machine/user software is identical. Additionally, Essemtec offers attractive solutions for financing and service.
Essemtec
Florian Schildein
http://www.essemtec.com/
This page has been viewed 120 times.
More from Essemtec
Essemtec
November 12, 2008 - Corporate News
Automatic SMD Insertion of Silicone Keys
Essemtec
October 9, 2008 - Corporate News
Essemtec to Exhibit at Mexitrónica
Essemtec
October 1, 2008 - Corporate News
Essemtec Opens New Demo and Training Center in Suzhou, China
Essemtec
September 23, 2008 - Corporate News
ESSEMTEC to Exhibit SP003-MLV at IPC Midwest
Essemtec
ESSEMTEC to Display RO300FC-C at IPC Midwest
ESSEMTEC
ESSEMTEC to Introduce SP150 at IPC Midwest
ESSEMTEC
ESSEMTEC to Feature EXPERT-SAFP Prototyping Station at IPC Midwest
Essemtec
ESSEMTEC to Display New Placement Machine at IPC Midwest
ESSEMTEC
ESSEMTEC to Premier FLX2011 to North American Industry at IPC Midwest
ESSEMTEC
Essemtec Introduces FLX2010C System
Essemtec
Essemtec Introduces Semi-automated Paste Printer Features
Essemtec
Essemtec Premiers Automated Printer with Sideways Moving Loading Drawer
Essemtec
ESSEMTEC Wins Global Technology Award for Multi-Flexible Production Solution
Essemtec
Essemtec provides even more customer benefits with enlarged service portfolio
Essemtec
August 20, 2008 - Corporate News
Essemtec's Placement Machine for Flex Board and Film Substrate Features Twin Vacuum Table
Essemtec
Essemtec to Highlight SP003-MLV Semiautomatic Stencil Printer with Vision at NEPCON South China
Essemtec
August 15, 2008 - Corporate News
Essemtec Introduces Semiautomatic Printer
Essemtec
ESSEMTEC to Highlight SP003-MLV at SMTAI
ESSEMTEC
Essemtec
August 13, 2008 - Corporate News
ESSEMTEC to Exhibit RO300FC-C at SMTAI
ESSEMTEC
ESSEMTEC to Feature EXPERT-SAFP Prototyping Station at SMTAI
Essemtec
Essemtec Introduces Semiautomatic SMT Prototyping System at NEPCON South China
Essemtec
August 7, 2008 - Corporate News
Essemtec Introduces Updated Web Site
Essemtec
August 6, 2008 - Corporate News
ESSEMTEC to Display New Placement Machine for Small and Mid-Size Production at SMTAI
Essemtec
To find more articles from Essemtec, use the search form below.
