Corporate News Index
August 7, 2008
Unique Boutique Clock Has UV Adhesive Solution
World renowned clocks have been made in Derby since the mid seventeen hundreds when clockmaker John Whithurst entertained his friends Benjamin Franklin and Charles Darwin at his house in Queen Street. So, when the Finesse Collection of hotels (www.thefinessecollection.com) were planning the reception area of their new boutique hotel in the town it was natural that they seek out the present day flag carriers of the Whithurst brand. Smith of Derby (http://www.smithofderby.com/) worked closely with James Blick, the Hotelier, to derive a contemporary design in keeping with the modern refurbishment of their traditional building.
The spectacular design by Kevin Litchfield did however call for some very specialist work. Explains Kevin “we needed to fit a glass map of the World into a fine stainless steel frame. The two-part adhesive we were using gave us problems so we called the team at Intertronics to discuss a UV cure alternative. Paul Whitehead arrived two hours later and basically did the job there and then.”
The Intertronics solution was to use DYMAX 429 which allowed plenty of time to accurately position the one-off and highly expensive components before rapid curing initiated with an IUV250 handheld UV lamp. Paul described the situation. “They were having problems getting the joint bubble free using a two-part epoxy – whereas the DYMAX 429 completely eliminated this problem and gave a virtually invisible bond in a matter of minutes.”
Reaction to the finished clock has been extremely positive with its unusual two-part electromechanical construction showing local time in one quadrant and global time in the other. The two elements are actually two separate clocks. One shows local time, indicative to the quarter of an hour. From 12am to 12pm (and vice versa) the hand travels through the quadrant, there are hour and quarter hour markings. As an example, if it is 11:59, the hand would be positioned at the bottom of the quadrant pointing downwards. At 12:00 the hand would travel back through the quadrant.
The second clock depicts world times through 24 zones – or the 24 countries mentioned on the clock itself. The reference point for clock is the UK, and then countries were selected that were an hour apart from the previous one. When looking at the clock the world map travels around and the time can be taken from the dial that surrounds the globe.
This was clearly a unique one-off situation with very expensive components where no mistake could be allowed for – but it was also a valuable learning experience and we understand that Smith of Derby already have another commission with similar requirements and already know the solution – Intertronics and DYMAX 429.
Intertronics
Peter Swanson
http://www.intertronics.co.uk
This page has been viewed 180 times.
More from Intertronics
December 23, 2008 - Corporate News
Intertronics Have The Answers!
Intertronics
December 2, 2008 - Corporate News
Light Enhancing, Heat Dissipating Silicones From Intertronics
Intertronics
November 24, 2008 - Corporate News
Intertronics Moves Conformal Coating Ahead Of The Game
Intertronics
October 29, 2008 - Corporate News
'They Nail Horses Shoes – Don’t They?' Asks Intertronics
Intertronics
October 8, 2008 - Corporate News
Into The Blue!
Intertronics
September 29, 2008 - Corporate News
Dymax Bluewave® Led System Now CE Marked From Intertronics
Intertronics
September 18, 2008 - Corporate News
Intertronics – Fine Mist Lubricant System
Intertronics
Free Visual Guide – Adhesive Dispensing Made Easy
Intertronics
August 7, 2008 - Corporate News
Intertronics
July 17, 2008 - Corporate News
“Adhere” Launches Premier Cyanoacrylate “Instant” Adhesive
Intertronics
June 12, 2008 - Corporate News
"Adhere" "Star" Product In Araldite 2000 Plus Range
Intertronics
May 19, 2008 - Corporate News
RFID Tag Bonding – Intertronics Addresses Harsh Supply Chain Applications
Intertronics
April 23, 2008 - Corporate News
Let Us Spray – ESD Coating From Intertronics
Intertronics
February 29, 2008 - Corporate News
Super Light-Weight – Super Performance Dispensing Valve
Intertronics
January 25, 2008 - Corporate News
Improving Industrial Dispensing With Pneumatic Valves
Intertronics
To find more articles from Intertronics, use the search form below.
