Corporate News Index
August 6, 2008
ESSEMTEC to Display New Placement Machine for Small and Mid-Size Production at SMTAI
Glassboro, NJ — Essemtec, a leading manufacturer of surface mount technology production equipment, announces that it will exhibit the multi flexible PANTERA-XV SMD placement system in booth 211 at the upcoming SMTA International 2008 exhibition and conference, scheduled to take place August 19-20, 2008, in Orlando, FL.
The PANTERA–XV SMD placement machine directly addresses prototyping and production runs in mid-sized quantities. The PANTERA-XV provides high placement accuracy and speed, a broad application range, high reliability and very low maintenance costs, as well as very short changeover times and excellent cost-performance ratio.
The PANTERA–XV placement machine handles the entire SMD range from 0201s to 50 x 50 mm QFPs with a fine pitch of 0.4 mm. Designed for the assembly of complex printed boards and fast changeover, the machine offers a large number of feeder slots (up to 108) in a small footprint of less than 1 square meter. All intelligent tape and stick feeders will be recognized automatically, regardless of the feeder slot being used. This provides for a very fast and error-free changeover process. The tape feeders are motorized and the transport speed is programmable. Also, 0201 chips can be reliably placed at a placement speed rated up to 4500 cph.
A further highlight of the system is increased precision, provided by the application of more accurate measuring systems. The resolution of the magnetic linear measuring system is 1 micron; the mechanism is not prone to dirt particles and dust and, therefore, provides high reliability and accuracy. For alignment, an integrated laser system measures small ICs and chip components "on the fly," and a bottom-up vision system is used for fine-pitch ICs or BGAs. Additionally, another vision system is installed for the automated correction of PCB positions as well as for the teach-in of component locations.
The PANTERA–XV placement machine can be customized to match the assembly task by a multitude of options. Just one example of many is the optional dispensing system for solder paste and adhesive that reduces the cost for stencils in prototyping and also allows for higher flexibility. A further example of the optional flexibility is the exchange of the universal standard magnetic PCB holder system.
The graphic-based software concept supports an extremely easy machine operation so that usage and programming can be quickly learned. Also, programming is a painless task: CAD data of layout software can be directly converted in an appropriate assembly program. In the case that such a data set is not available, the components can be placed manually (i.e. virtually) by means of an integrated camera.
The PANTERA–XV SMD placement machine is designed for the flexible assembly of small and mid-sized production volumes. With its solid construction and high reliability, the equipment can be used efficiently for larger production quantities.
With this machine, users also have access to Essemtec’s remote maintenance system and to the MyEssemtec.com user portal on the Internet. Of great importance for the customers’ decision and production planning is the save-investment program: in the case that the production requirements might change over time, Essemtec guarantees a fair price for the used machine, based on its age, in return for a faster piece of equipment. The existing assembly programs still can be used and the machine/user software is identical. Additionally, Essemtec offers attractive solutions for financing and service.
Essemtec
http://www.essemtec.com
This page has been viewed 369 times.
More from Essemtec
Essemtec
November 12, 2008 - Corporate News
Automatic SMD Insertion of Silicone Keys
Essemtec
October 9, 2008 - Corporate News
Essemtec to Exhibit at Mexitrónica
Essemtec
October 1, 2008 - Corporate News
Essemtec Opens New Demo and Training Center in Suzhou, China
Essemtec
September 23, 2008 - Corporate News
ESSEMTEC to Exhibit SP003-MLV at IPC Midwest
Essemtec
ESSEMTEC to Display RO300FC-C at IPC Midwest
ESSEMTEC
ESSEMTEC to Introduce SP150 at IPC Midwest
ESSEMTEC
ESSEMTEC to Feature EXPERT-SAFP Prototyping Station at IPC Midwest
Essemtec
ESSEMTEC to Display New Placement Machine at IPC Midwest
ESSEMTEC
ESSEMTEC to Premier FLX2011 to North American Industry at IPC Midwest
ESSEMTEC
Essemtec Introduces FLX2010C System
Essemtec
Essemtec Introduces Semi-automated Paste Printer Features
Essemtec
Essemtec Premiers Automated Printer with Sideways Moving Loading Drawer
Essemtec
ESSEMTEC Wins Global Technology Award for Multi-Flexible Production Solution
Essemtec
Essemtec provides even more customer benefits with enlarged service portfolio
Essemtec
August 20, 2008 - Corporate News
Essemtec's Placement Machine for Flex Board and Film Substrate Features Twin Vacuum Table
Essemtec
Essemtec to Highlight SP003-MLV Semiautomatic Stencil Printer with Vision at NEPCON South China
Essemtec
August 15, 2008 - Corporate News
Essemtec Introduces Semiautomatic Printer
Essemtec
ESSEMTEC to Highlight SP003-MLV at SMTAI
ESSEMTEC
New placement machine for small to middle-sized production volumes from ESSEMTEC at NEPCON South China
Essemtec
August 13, 2008 - Corporate News
ESSEMTEC to Exhibit RO300FC-C at SMTAI
ESSEMTEC
ESSEMTEC to Feature EXPERT-SAFP Prototyping Station at SMTAI
Essemtec
Essemtec Introduces Semiautomatic SMT Prototyping System at NEPCON South China
Essemtec
August 7, 2008 - Corporate News
Essemtec Introduces Updated Web Site
Essemtec
August 6, 2008 - Corporate News
Essemtec
To find more articles from Essemtec, use the search form below.
