RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces the release of Trident III, its automatic defluxing and cleanliness testing system in booth 207 at the SMTA International 2008 exhibition and conference, scheduled to take place August 19-20, 2008 in Orlando, FL. The Trident Series represents the next generation of lead-free compatible, fully automatic post-reflow defluxing systems.
Trident III is capable of removing all flux residues including rosin, no-clean and water soluble. Both lead and lead-free flux residues may be removed using the system, and it is equipped with an automatic chemical injection system that automatically adds a programmable volume of defluxing chemical to the wash water.
Trident III is equipped with a closed-loop wash solution recycling system. Wash solution is heated automatically and sprayed onto the assemblies. At the end of the wash cycle, the wash solution is directed back to the wash solution holding tank for subsequent reuse. Rinse water is then sprayed onto the assemblies until the desired cleanliness level is achieved. All rinse water is directed through the pre-drain filtration system then sent to drain. Assemblies are dried via the on-board convection and radiant forced air drying system.
Trident III is equipped with a host of standard features including programmable maintenance reminders, remote SPC viewing, SPC data USB export and a built-in chemical management system. An optional zero-discharge evaporation system eliminates connection to a drain line.
The automatic defluxing system is reportedly the fastest batch-format defluxing system available. Trident’s specific throughput rate is determined by board size. The Trident III is capable of defluxing and cleanliness testing up to 200 4 x 6" (101 x 152 mm) boards and up to 28 18 x 20" (457 x 508 mm) boards per hour.
