July 28, 2008
Procedure for handling moisture sensitive PCB's
IPC-JEDEC J-STD 0020B provides guidance concerning handling and packaging of moisture sensitive devices. PCBs are also moisture sensitive devices.
What MSD Level is commonly used for multi layer PCBs?
Mike Gearhart
Novatel Wireless
This "Ask the Experts" page has been viewed 816 times.
August 1, 2008
IPC task group D-35 is developing a guide for storage and handling of bare boards. This group has recently expanded the scope of the project to include test methods for classifying MSL of bare boards.
IPC, ECA and JEDEC are preparing to publlish J-STD-075 that will provide moisture and thermal classification methods for passives, connectors, switches--anything else that might go through a wave or reflow oven (except PCBs). J075 is projected to be released by the end of August. BTW, J-STD-033 is the correct standard for handling & packaging MSDs.
Jack Crawford, Director - Certification & Assembly Technology
IPC
crawja@ipc.org
Mr. Crawford is Director of Certification and Assembly Technology for IPC and a former member of the SMTA Board of Directors. He is technical liaison to the IPC committees that maintain critical industry standards like IPC-A-610, J-standards, and IPC/WHMA-A-620 cable and wire harness standard, is an accomplished author, and has presented numerous papers internationally.
July 27, 2008
With the introduction of lead free, the risks associated with marginal or improper handling of MSDs has increased dramatically. Higher reflow temperatures drive up the saturated vapor pressure to double or even triple that present in tin lead reflow processes.
The higher temperature increases the water pressure inside the components, and as a result, the allowable moisture content and associated floor life have to be reduced. All moisture-sensitive components have to be requalified by their manufacturers for lead-free and they are typically downgraded by at least one and generally two levels of sensitivity.
This significantly affects how components must be are handled, processed and stored. Suddenly, manufacturers that are currently handling MSL 2 or MSL 3 components are now looking at processing MSL 5 or MSL 6.
The SMTA’s MSD Council is among the those who have reported that even passive components (ceramic chip resistors and capacitors), normally classified as MSL 1 (unlimited floor life) have shown field failures after lead free reflow due to presence of moisture in the component.
Another major impact of lead free reflow for assemblers is the handling and storage of PWBs, as the incidence of delamination has increased with the change in thermal processing. PWBs need to be treated as MSL classification 4, in other words processed within 72 hours of open shop floor time. See http://www.superdry.info/
Richard Heimsch, Director
Protean Marketing
rich@proteanmarketing.com
Now a director at Protean Marketing, Mr. Heimsch has worked in the electronics industry 25+ years in a wide variety of international sales, marketing and operations roles. After spending many yearts in Europe and Asia, Rich now resides in the US where he spearheads Protean's international business development, specializing in Brand Management and Strategic Communications.
