Corporate News Index
July 21, 2008
DYMAX Corporation is pleased to introduce a new tack-free, soft gasket material for sealing fuel cells, appliance housings, and critical electronic assemblies and devices. Light Weld® GA-140 is a UV/Visible light-curable form-in-place (FIP) and cure-in-place (CIP) gasket developed for applications requiring low compression set, tack-free surface, and durable, reliable sealing. It is a soft gasket material with high adhesion to plastics which provides a barrier to prevent absorption or penetration of air, dust, moisture, liquids and gaseous substances.
This gasketing material can be dispensed into intricate and complex configurations with the benefit of in-line curing which allows for increased production speed, greater output, lower processing costs, and reduced inventories. It is a silicone-free, one-part resin requiring no mixing. GA-140 is low out-gassing, cures in seconds, and its viscosity allows for varying bead heights. It conforms to intricate channels or recesses and has excellent tear resistance for serviceable and limited-service applications.
DYMAX FIP gaskets cure completely in seconds even in 1/4”-thick beads. No more racking, stacking, waiting, and un-racking as required with traditional FIP gaskets. DYMAX light-curing FIP gaskets offer the ultimate in gasket design flexibility. Designed for flat flanges or wide shallow grooves, permanent FIP gaskets can eliminate the delay experienced with slow-curing resins as well as the design, inventory, and labor expense associated with pre-cut gaskets. DYMAX gaskets cure faster and deeper than UV silicone, and do not release corrosive chemical by-products upon cure.
DYMAX Corporation
http://www.dymax.com/
This page has been viewed 169 times.
More from DYMAX Corporation
DYMAX Corporation
November 13, 2008 - Corporate News
New Dymax ACCU-CAL™ 50V Visible Radiometer
Dymax Corporation
DYMAX - One of the Fastest-Growing Companies in the U.S.
DYMAX Corporation
October 23, 2008 - Corporate News
DYMAX + PARTNER PAK = Sustainable Clamshell Packaging Technology
DYMAX
October 22, 2008 - Corporate News
DYMAX Plastic-Bonding Adhesives Pair Well with New BlueWave® LED Spot Curing System
DYMAX Corporation
DYMAX Acquires Dispensing Leader Tridak
DYMAX Corporation
September 26, 2008 - Corporate News
DYMAX Corporation
September 25, 2008 - Corporate News
DYMAX
September 24, 2008 - Corporate News
New DYMAX ACCU-CAL™ 50V Visible Radiometer
DYMAX
DYMAX
New Moisture-Resistant Gasketing Resin from DYMAX
DYMAX Corporation
July 28, 2008 - Corporate News
DYMAX BlueWave LED System Now CE Marked for Global Distribution
DYMAX
DYMAX Corporation
July 14, 2008 - Corporate News
DYMAX Introduces Fluorescing Light-Curing Needle Bonding Adhesive
DYMAX Corporation
July 11, 2008 - Corporate News
Fluorescing Light-Curing Needle Bonding Adhesive from Dymax
DYMAX Corporation
June 6, 2008 - Corporate News
New Conformal Coating from DYMAX Meets MIL-I-46058C and IPC-CC-830B Requirements
DYMAX Corporation
May 8, 2008 - Corporate News
New Conformal Coating from DYMAX Meets Requirements
DYMAX Corporation
May 7, 2008 - Corporate News
Mr. Kyle Rhodes Joins DYMAX as Medical Market Segment Manager
Dymax
May 6, 2008 - Corporate News
Mr. Terrence Woldorf Joins DYMAX Corporation's Sales and Marketing Team
DYMAX Corporation
April 16, 2008 - Corporate News
Get Cool, Consistent, Visible Light Curing with New DYMAX BlueWaveTM LED System
DYMAX Corp.
180° Curing w/ New DYMAX UVCS SideCure™ Conveyor System
DYMAX Corp.
April 14, 2008 - Corporate News
Rob Kleinschmidt Joins DYMAX as Sales Engineer
DYMAX Corporation
April 10, 2008 - Corporate News
DYMAX Introduces See-CureTM Technology
Dymax
DYMAX Corporation
March 26, 2008 - Corporate News
DYMAX Corporation
To find more articles from DYMAX Corporation, use the search form below.
