Corporate News Index
June 23, 2008
JTAG Technologies Breaks the Barrier between Functional Testing and Boundary-scan
 New RMI ideal for instrumentation racks and desktop use
Stevensville MD - JTAG Technologies, a leading provider of IEEE Std. 1149.x-based solutions for testing and in-system programming of PCBs, has tackled the barrier between structural and functional testing. With the announcement of the newest member of the high-performance DataBlaster line of boundary-scan controllers, it becomes a simple matter for electronics manufacturers to combine boundary-scan performance and test coverage with functional validation.
The new JT 37x7 / RMI (rack-mounted instrument) is conveniently packaged in a standard 19-inch by 1U form factor for compatibility with virtually any rack-mounted functional test system. The RMI supports all boundary-scan test applications including IEEE 1149.6 advanced digital network testing as well as in-system programming (ISP) of flash memories and programmable logic devices. With its four fully-compliant boundary-scan test access ports (TAPs), the RMI delivers excellent signal integrity at the target. In addition, the RMI provides 256 programmable I/Os to further enhance test coverage.
TAPs and I/Os are available on the front panel of the unit, and the TAPs can be combined for test purposes or ganged for high-throughput testing and ISP. The TAPs can also be extended via flat cables from the front panel to satisfy special fixturing requirements. I/O channels are individually programmable as input, output, bi-directional or tri-state, and voltage thresholds can be programmed to 1.5, 1.8, 2.5, or 3.3V for use with modern low-voltage logic families. To reduce scan chain length and improve test efficiency, any number of 16-channel groups can be bypassed.
The RMI is powered from the host computer and interfaces to the computer via three standard formats, USB 2.0, Ethernet 10/100 and IEEE 1394 Firewire, giving it nearly universal applicability and ease-of-use. Test clock frequency is programmable up to 40 MHz allowing very rapid application execution, especially important for flash programming, while TAP voltages can be set for a wide range of input and output characteristics.
Ray Dellecker, marketing manager for JTAG Technologies, comments, “We wanted to be able to give our users a convenient way to combine their boundary-scan operations with functional testing. The RMI meets the need perfectly—it’s platform-neutral, equally at home in PXI-, VXI- or PCI-based test environments. And, because the RMI is completely self-contained with no auxiliary units, it is easily moved between test stations. Furthermore, in addition to rack-mounted test setups, the RMI is ideal for benchtop applications.”
The new controller is fully compatible with all JTAG Technologies’ development tools such as JTAG ProVisionTM and JTAG Visualizer. In combination with functional testing, the RMI works seamlessly with the industry’s most popular architectures including National Instruments LabVIEW, LabWindows and TestStand as well as custom C/C++ and Visual Basic test systems. Pricing for the JT 37x7/RMI begins at $6,500; the product is available for immediate shipment.
JTAG Technologies
Ray Dellecker
http://www.jtag.com/
This page has been viewed 163 times.
More from JTAG Technologies
December 2, 2008 - Corporate News
JTAG Technologies introduces new I/O module
JTAG Technologies
September 5, 2008 - Corporate News
JTAG Technologies with new Hard- and Software at electronica 2008
JTAG Technologies, Inc.
August 22, 2008 - Corporate News
JTAG Technologies' ProVision raises the boundary-scan bar
JTAG Technologies
June 24, 2008 - Corporate News
JTAG Technologies supports wide range of Freescale controllers
JTAG Technologies
June 23, 2008 - Corporate News
JTAG Technologies
May 15, 2008 - Corporate News
New JTAG products at NEW
JTAG Technologies
To find more articles from JTAG Technologies, use the search form below.
