Corporate News Index
June 11, 2008
Turnkey Diode Laser System Delivers Higher Power & Brightness
Santa Clara, Calif. – The newest turnkey diode laser system from Coherent, Inc. (Santa Clara, CA) (Nasdaq:COHR) offers higher output power and brightness than previously available from the company. Specifically, the HB-diode system delivers 75W of power at either 808 nm from a 200 µm core 0.22 NA (numerical aperture) fiber, or 976 nm from a 400 µm core 0.22 NA fiber. The HB-diode system is a fully integrated, microprocessor controlled instrument that operates from 110/220VAC, and enables user control of diode output through either a front panel keypad or electronic interface, including analog, TTL, RS-232 and RS-485. Other convenience features include air cooling, a rack mounting option, and a coaxial, visible wavelength aiming beam.
The high power and brightness of the new HB-Diode System, together with its reliability and ease of use, make it particularly well suited for applications in materials processing, medical therapeutics and pumping solid-state laser media. These include plastics welding, electronics soldering, solar cell contact soldering, Rb vapor pumping, RFID bonding, plastics marking, heat treating, hard drive arm heating, dermatological and dental treatments and photodynamic therapy.
Coherent, Inc.
Andre McFayden
http://www.Coherent.com
This page has been viewed 76 times.
More from Coherent, Inc.
YESTech
IPC
Agilent Technologies Announce Additional In-Circuit Test Capacity at Solution Sources
XDry Corporation
PROMATION, Inc.
A.C.E. Production Tech Opens Selective Soldering Process Development Lab
Cobar
Krayden
Pennies Well Spent
PULS UK
ZESTRON America
DYMAX Corporation
Fine Line Stencil
Reed Exhibitions
AVX Corporation
Littelfuse
CheckSum
Orbotech Ltd.
Essemtec
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
To find more articles from Coherent, Inc., use the search form below.
