Leading Bond Test Manufacturer DAGE Appoints Inseto As Their New UK & Irish Distributor
Prologue:
Dage the worldwide leader for Bond Testers has appointed Inseto as their new UK and Irish distributor.
Dage Bond Testing equipment includes Multifunction Wire Pull, Bond & Die Shear, Tweezer and Stud Pull capabilities as well as the innovative High Speed Shear Testing for evaluating solder bump adhesion.
Inseto provides advanced assembly and test equipment plus related consumable products for electronic production, including Semiconductor, PCB & Microelectronic Assembly.
Dage the industries leading manufacturer for Multi Purpose Bond Testers, has appointed Inseto as their new and Irish distributor. “We are delighted to have secured the distribution of the Dage Bond Testing Systems, which complements our other leading brands of die and wire bonding equipment and consumable products”, said Inseto Sales Director Matthew Brown.
The Dage product line includes their Series 4000 Multi Function Bond Tester, which with over 4000 sold worldwide, is the industries leading modular bond test platform. This system is capable being configured as a simple wire pull tester through to a system capable of performing up to eight different types of test including: wire pull, bond shear, die shear, stud pull, tweezer pull, vectored pull etc.
The 4000 utilises patented frictionless load cartridges and air bearing technologies, which ensure maximum accuracy, repeatability and reproducibility. Cartridges for different applications are readily exchanged and can be stored on the system until required.
Inseto is also offering support for all existing users, including provision of OEM consumable wire pull hooks, shear tools and spare parts, plus calibration, maintenance and equipment recovery by factory trained personnel.
