Corporate News Index
June 10, 2008
Crystek Corp Introduces World’s Smallest High-Performance CRO
Crystek Corporation Introduces World’s Smallest High-Performance Coaxial Resonator Oscillator (CRO) In Compact .38x.38-In Package
Fort Myers, FL Crystek Corporation has expanded its line of ultra-low phase noise Voltage Controlled Oscillators (VCOs) with a new coaxial resonator oscillator. The model CVCO38CC-3660-3700 VCO is packaged in the super-compact 0.380-in. x 0.380-in. x 0.220-in. SMD package, achieving 42% space savings over the standard 0.5-in x 0.5-in package.
The CVCO38CC-3660-3700 operates from 3660 MHz to 3700 MHz with a tuning voltage range of 0.3 Vdc to 4.7 Vdc. (The CVCO38CC family is available in models that operate from 2.2GHz to 4.4GHz in bands.) This coaxial VCO features a typical phase noise of -108.69 dBc/Hz @ 10KHz offset and has excellent linearity.
It exhibits an output power of +4.0 dBm typ. into a 50 ohm load with a supply of +5.0 Vdc and a typical current consumption of 30 mA. Pushing and Pulling are both minimized to 1.0 MHz/V and 2.5 MHz, respectively. Second harmonic suppression is -15 dBc typical.
The CVCO38CC-3660-3700 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
Pricing for the CVCO38CC-3660-3700 will start at $15 ea. in volume. For additional pricing details, contact Crystek Corporation.
Crystek Corporation
http://www.crystek.com
This page has been viewed 122 times.
More from Crystek Corporation
YESTech
IPC
Agilent Technologies Announce Additional In-Circuit Test Capacity at Solution Sources
XDry Corporation
PROMATION, Inc.
A.C.E. Production Tech Opens Selective Soldering Process Development Lab
Cobar
Krayden
Pennies Well Spent
PULS UK
ZESTRON America
DYMAX Corporation
Fine Line Stencil
Reed Exhibitions
AVX Corporation
Littelfuse
CheckSum
Orbotech Ltd.
Essemtec
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
To find more articles from Crystek Corporation, use the search form below.
